Volume problem with old Blues Deluxe
The other guitar player in my band has an old Blues Deluxe (4 x 10) and recently had a problem with the volume coming and going towards the end of a gig.
He replaced the power tubes and everything seemed to be fine at band practice on Monday evening - although we weren't playing loud. He left the amp in my music room and suggested that I play through it this week to see whether the problem had been cured. All seemed well last night. I had the amp going for almost 2 hours and didn't hear anything untoward. But this wasn't at anything like gig levels. This morning I thought I'd try it again but at louder volumes. After only about 5 minutes or so, the volume suddenly died and then came back again after only a second or so. This happened several times within a very short time. So I switched the amp off. I had the guitar on 10 and the amp was set pretty loud as well - probably close to gigging volume. There were no weird noises or crackles when this happened, the volume just died and then came back. Tonally the amp sounds fine. I phoned my friend and he's going to take the amp into a local repair workshop but I'm curious to hear what might be wrong with it. Any ideas??
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad...... www.reverbnation.com/delthomas1 www.myspace.com/delthomas www.myspace.com/manalishinz |
Many possibilities. And...the intermitten, come-n-go quickly aspect makes it hard to diagnose. I first suspect electrolytics when something like this happens. That amp may be of an age where the electrolytics are suspect. PReamp tube?? HEater filament has a cnnection coming and going...I doubt it, but just musing.. BAd connection almost anywhere that affects voltage to the tubes. THe connection thing would very likelyhave a pop! going along with it or a crackling....
The electrolytics keep coming back to mind. What happens when you slap the fire out of the side or top of the amp? |
I didn't try giving the amp a knock or anything. I was more concerned that I didn't cause any more damage to whatever's wrong with it so I just switched it off and left it.
My friend came and picked it up last night and is taking it to a local repair shop today - we need it back for a gig next Thursday! It could well be something inside the amp that's a bit tired. It's about 11-12 years old and I don't think he's been too interested in getting it regularly serviced over the years other than changing tubes occasionally.
Del, I couldn't help but chuckle. When one of these is acting this way, I am hoping that a good slap/knock/kick will yield a permanence for the flaw. That way, it can be found! LOL I amthinking that this amp is not suffereing from a bad connection, but I could be wrong. LET us know what is found, okay. Learning is.
#5 (permalink) | |
well, that's whats acting up on my old BDX ![]() and yes, what Wally said: Many possibilities...
....and That's When the Racoon Attacked My Leghttp://www.myspace.com/timebanditsberlin |
