Old February 22nd, 2010, 04:01 PM   #1 (permalink)
jjkrause84's Avatar
Nature's Attenuator
A pillow!
Man....this is gonna sound so stupid but I can't believe how well it works! Sure I love feeling the vibration of the ground under my feet and feeling my pulse quicken with that first monster chord but, hey....I got neighbours!
Anyone else regularly use a pillow?
jjkrause84 is offline   Reply With Quote
Old February 22nd, 2010, 05:18 PM   #2 (permalink)
MaskedRider's Avatar
Originally Posted by jjkrause84 View Post
A pillow!
I can't sleep without one.
MaskedRider is offline   Reply With Quote
Old February 22nd, 2010, 05:32 PM   #3 (permalink)
woodman's Avatar
Long ago in a similar situation, i'd put the amp up on the couch.
It pays to appease all the gods — Gnossos Pappadopoulis
Original tunes from the Woodshed
Old February 22nd, 2010, 07:28 PM   #4 (permalink)
Nash's Avatar
I use a pillow all the time, the only problem is the back of the amp is left exposed so it still gets pretty darn loud if I'm not careful.
Some people are wise and some are otherwise.
Nash is offline   Reply With Quote
Old February 22nd, 2010, 07:38 PM   #5 (permalink)
I am serious! Has anyone ever tried a Light Dimmer Switch as an attenuator?
I don't need no I.D.,I know who I am,I'm Tommy Bolin!
Post Toastie is offline   Reply With Quote
Old February 22nd, 2010, 07:43 PM   #6 (permalink)
woodman's Avatar
That was the good thing about the couch — you could situate it so you had plenty of ventilation, but the back of the couch would soak up the backblast. A big stuffed chair would work too.
Old February 22nd, 2010, 09:17 PM   #7 (permalink)
They are usually "choppers" in that they reduce voltage by chopping the tops of the wavefrom off. Maybe as an effect, but not close to a clean anttenuator
celeste is offline   Reply With Quote
Old February 22nd, 2010, 09:42 PM   #8 (permalink)
Then can they be used as a variac?
Old February 23rd, 2010, 06:49 AM   #9 (permalink)
Stewart Ward's Avatar
No! They are far too noisey for this purpose.
Variacs can be used to lower the operating voltages to create early distortion, but if your amp is tube, turning down the mains volatge ALSO reduces the heater voltage. So the tubes run cool and inefficiently (even more than normal)!
Just use a decent pedal with your amp!?
Stewart Ward is offline   Reply With Quote
