Negative feedback
So I have a Music Man HD-130 210 with the 12ax7 P.I. that I got a little while back. The previous owner installed a neg. feedback switch on the amp. Stock is negative feedback on and when you throw the switch there is no neg. feed back. My question is what exactly does this do and what exactly is neg. feedback and impact on sound without ?
Thanks Edit: I'm getting some answers on the Shock brothers section.
Steve Last edited by ASC67; February 3rd, 2010 at 07:09 PM. |
A negative feedback loop takes negative energy from the speaker and feeds it back into the circuit at the phase inverter/driver. The effect is partial phase cancellation (the negative feedback is out-of-phase, relative to the "regular" signal), resulting in greater clarity and less distortion. A flick of the switch will be a better description than words, but that's what's going on. It depends on the amp, how "hot" you're running it and what you need whether negative feedback is desirable or not.
There is no substitute for Sound Pressure Level |
I did this on a blues jr. At lower volume with no NFB, it sounded bigger and looser and a hair noiser. For the blues jr, no NFB at low to mid volumes made it a boutique amp. Also increases the touch sensitivity. Got rid of the boxy sound.
But if playing with a lot of people and loud, you probably want NFB because it keeps the amp tone more focused and less extreme excursions especially on the low end (or at least turn the bass down). You can also put in a variable resistor and dial in what you like. |
#5 (permalink) | |
I think he meant the electro mechanics, he obviously can hear it. ![]()
A Twin always will cut it... but I don't recommend it for everybody. It's like a big dog, you have to take responsibility for it. Not to mention... be prepared to lift it. BTW, how $good$ a guitar is, is no indicator of how badly it can be played! |
Negative feed back loop... Usually the missing link in amps claiming to be class A.
www.myspace.com/redtele2 http://www.reverbnation.com/#/redtele If the music business was easy, then smart people would do it. |
