Old March 21st, 2003, 05:22 PM   #1 (permalink)
Michael Murphy's Avatar
Location: I can hit the Pacific Ocean and/or Canada with a rock from here...
Pulling Power tube Q's
I have a 45w speaker in an enclosure that I need to test, and the only amp I have available at the moment is an old Dual Showman.
I want to see how it does with an amp with compatible power output running at or close to full power.
I can pull two of the Showman's power tubes and be in the ballpark, can't I? It's my understanding that either the outside pair or inside pair should be pulled, and that will give me about half of the normal power output w/o damaging the amp.
Is that correct? Or do I just need to wait until I have the correct amp at hand?
Don't wanna blow nuttin' up....
Thanks in advance,
-Michael
Charter Member S. Texas He-man emoticon-haters Local #316
Just an analog boy in a digital world...
Michael Murphy is offline   Reply With Quote
Old March 22nd, 2003, 03:21 PM   #2 (permalink)
jazzguitar's Avatar
I think you can do that, but
even with only two power tubes there may be more than 45 watts.
jazzguitar is offline   Reply With Quote
Old March 22nd, 2003, 06:54 PM   #3 (permalink)
The amp is only rated at 85 watts- so I figure that would put me in the ballpark, power-wise.
My main concern is damaging the amp. I just wanted to know if this procedure is OK for it, and which pair I should remove (or if that matters).
Anybody know?
Thanks,
-Michael
Old March 22nd, 2003, 07:40 PM   #4 (permalink)
Silverface's Avatar
depends
If it's an 8 ohm or 4 ohm speaker you should be fine for test purposes. I'd suggest rebiasing when you do it though just to be safe. If you n
The amp is "rated" at 85 watts - but even cranked up you won't get more than about 35 watts or so out of two tubes. Vintage amp wattage ratings are almost always exaggerated...based on max power dissipation, which you can get - if you want to have your tubes last for 30 seconds or so.
If it's a vintage speaker chances are it wouldn't handle 45 watts without a recone anyway.
“No Chops – Great Tone” ©
Old March 22nd, 2003, 07:53 PM   #5 (permalink)
Hmmm. Guess I'll wait a few days.
Thanks for the info.....
-Michael
vB code is On
Forums Directory
