Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Lace Music Products Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old December 8th, 2009, 07:11 PM   #1 (permalink)
PRRI Tungsol bias Question
I have a PRRI that I have done the OT upgrade and have put in a set of jj 6v6 tubes. The origional GT or Electro Harmonix 6v6 tubes were biased at 22ma so I biased the JJ 6v6's there as well. I usually play clean and am happy with the tone of the amp except when it is dirty It sounds brittle. I seem to play at a vol. that is on the verge of clean and dirty. I have heard good comments on the tungsol tubes so I thought I would give them a shot hoping that if I did play loud enough that maybe it wouldn't be as brittle.
All this and now my question. When I ordered the tubes I asked if they had a bias recommendation and they said it would be on the tube.
My receipt says bias point 1.0 What does that mean? and my Tubes say bias point 33 What does that mean?
any help is greatly appreciated steve
steve from mo. is offline   Reply With Quote
Old December 9th, 2009, 01:39 AM   #2 (permalink)
Scott S's Avatar
The PRRI's stock bias is 23mA per tube, which is not as cold as you might think, considering the plate voltage of 440V(!) JJ's can handle a lot of dissipation, but I'd check the plate voltage in your amp before going too crazy with the bias.
(I'm not sure what the "bias point" numbers mean, either...)
- Scott
Wound thirds are my anti-wank.
Old December 9th, 2009, 02:00 AM   #3 (permalink)
jefrs's Avatar
Imo the JJ 6V6GTS is a 5881 with a smaller heater current and they can run very hot indeed. I've used them in place of 6L6GC with no problems, very loud, very clean, not brittle. I expected less headroom, they stayed clean. Probably one of the best 6V6 types. Perhaps it's your JJs that want re-biasing. On the other hand you may need a proper 6V6.
jefrs is online now   Reply With Quote
Old December 9th, 2009, 08:29 AM   #4 (permalink)
Stan Martin's Avatar
try goosing the bias
to 28mA, if it does start to red plate back off the bias a wee bit. btw- I don't know how faithful the reissue is, so you may not have a bias pot in there. If you don't have a pot consider adding one.
Stan Martin is offline   Reply With Quote
BIAS VS. Tone Question PRRI steve from mo. Amp Central Station 5 September 20th, 2009 01:09 PM
To bias or how to bias... that is the question jimmynumber9 Amp Central Station 11 June 4th, 2009 08:56 AM
Will these tungsol 5881's work in my amp? singlecoil Amp Central Station 6 April 6th, 2009 07:51 PM
Question on PRRI reverb and noise stevehuff69 Amp Central Station 5 November 25th, 2008 10:15 AM
Tungsol 5881 Reissue in a Deluxe Reverb RI nonvintage Amp Central Station 5 January 19th, 2007 01:31 AM
