Old November 6th, 2009, 02:45 PM   #1 (permalink)
15 inch speaker for 5E3
I have been thinking about pairing up my 5E3 with a 15" speaker. I'll likely get a combo cab made for it so I don't have to have a combo and ext. speaker cabinet.
Do any of you have any experience with a 5E3 and a 15" speaker?
Do any of you have any speaker recommendations? I have a weber Sig. 12S alnico in it right now.
I would like a little more bottom end and a little later breakup. I assume that just adding a 15" speaker and pro (5E5) cabinet will add some bottom end before any speaker is concerned, but what would you recommend? I play (try anyway) 40's, 50's 60's music, you pick the genre.
screamin eagle is offline   Reply With Quote
Old November 6th, 2009, 03:51 PM   #2 (permalink)
I've got an Eminence Legend 15" that came stock with my Gretsch Executive amp. It sounds like it may be what you're looking for. The amp is clean and it breaks up later on the volume knob than most amps in its power range, but that probably has more to do with the amp circuitry. I really like the speaker though and have no plans to change it, even though I almost always swap out stock speakers. For what it's worth, the amp was made by Victoria amps and that speaker is what they use in their 15" speaker amps.
Sorry, no experience running a tweed amp through that speaker.
ac15 is offline   Reply With Quote
Old November 7th, 2009, 02:52 PM   #3 (permalink)
woodman's Avatar
i think you're on the right track with the Weber alnico, just not the Sig ... one time, just for grins, i plugged the 15A150 from my brown Pro (still in the Pro cabinet) into my 5E3 and it was fairly majestic sounding. ... if you want later breakup, i'd think about avoiding the Sig series and going for something more efficient like the 150 voice coils. in fact, you could try one of the 12A150 variations and get more and tighter bottom end and later breakup in your existing 12" cabinet. you should be able to sell the Sig for a pretty decent nickel.
Old November 8th, 2009, 09:35 AM   #4 (permalink)
It seems to me that you can probably get what you want by replacing the Weber Sig 12S with another 12" speaker. That way you won't have to go to the trouble of replacing the speaker AND the cabinet (which strikes me as a lot of trouble).
I had a Weber alnico Sig 12S in my 5E3 for awhile. It is a wonderful value speaker for getting that snappy Jensen P12R sound at low volumes and it breaks up beautifully, but the bass is not crisp and firm (the alnico circuit has a lot of "give" to it when pushed). I actually went back to the generic Eminence ceramic 12" speaker I originally put in the amp when I got it. It solves the problems you mentioned--it is louder before breakup and the bass is more firm. If you want to go that route, Victoria is now putting Eminence Legend 1258 ceramic speakers in their 5E3 clones, and that would be a good place to start. Hope this helps.
Dr. Bill
Dr. Bill is offline   Reply With Quote
15 inch speaker? gruveb Amp Central Station 32 November 5th, 2009 03:13 AM
15 Inch Speaker sort of like a C.Rex? telel6s Amp Central Station 3 April 11th, 2009 10:53 PM
12-inch 4-ohm speaker JoeNeri Amp Central Station 7 October 18th, 2007 08:14 PM
modern 15 inch speaker Maestro Amp Central Station 11 November 10th, 2006 04:41 AM
12 inch 4 ohm speaker for a Champ? Sidney Vicious Amp Central Station 6 August 28th, 2006 03:04 PM
