Old November 4th, 2009, 07:54 PM   #1 (permalink)
Top Boost=Zilch!
So last week I was having issues with my Vox AC30CC1. I was getting nothing out of it. No sound, once in awhile it would make an odd noise. Fast Forward to today. I replaced all the tubes. 4 JJ EL84's 3 Mullard 12AX7's and a Mesa 5AR4. I fire up the amp and I only get sound from the normal input. When I plug into the Top Boost I get no sound whatsoever. If I switch over the input link switch I still only get clean from it. I get nothing from the top boost. Any ideas?
oneleftnut is offline   Reply With Quote
Clean Boost pedal vs db boost pedal??? cactusrob The Stomp Box 6 September 1st, 2009 12:15 AM
bad bob boost raf The Stomp Box 32 December 17th, 2007 07:35 PM
Compact Boost with Separate Boost and Level Controls Hoodster The Stomp Box 5 July 10th, 2007 05:15 PM
boost-comp-boost-OD-boost...(ad infinitum ad nauseum) kenoflife The Stomp Box 2 June 21st, 2006 07:38 PM
Katana Boost or Java Boost?? silentkid The Stomp Box 9 September 14th, 2005 06:25 PM
