Vintage Mesa Boogie Question
Hi everyone,
A local music store has a Mesa Boogie that I'd been eyeing for a while: it's a blonde 1x12 combo, and it looks pretty unassuming. It's also in really good shape. Anyways, I went in and tried it out today, and it absolutely sings. Now, I asked the guy at the counter if he knew anything about it, and he said "Yeah, it's a Mark I. Pretty cool, huh?" So the end result is that I'm wondering whether I should be scrounging around and saving pennies for the $1000 (CAD) they're asking for it. I'll try and talk the price down, but is it worth that much? Thanks! |
A vintage MK I for $1000? I paid $1200 for my reissue, (but it does have the hardwood cab and EV speaker). It's a great amp if that's the sound you're after.
What options does it have? (60/100 watt switch, reverb, EQ and speaker choice) |
A MkI Boogie is a pretty cool piece. If it were a Dumble or a Kelley from the same era we'd be having a discussion of how can they possibly be worth that much? A Kelley is a bargain compared to a Dumble. So, in the context of vintage exotica that old MkI is cheap.
Here's how that came to pass: Randall Smith dba "Boogie" offered high quality handbuilt amps prior to the '80s. They used to torture test / burn in each amp, the procedure involved a 24 hour burn-in minimum with the amp cranked in a test cell and subjected to hammer blows. Any amp that did anything funky during burn-in went through a re-work procedcure then was subjected to another burn-in, sort of a boot camp for amps. This during an era when most manufacturers were hustling to get away from tube amps and build solid state designs. They're not outrageously expensive because Boogie went on to become a more mainstream manufacturer while other boutique builders didn't. I have a hard time coming up with anything negative to say about an amp that will withstand repeated hammer blows. Just consider for a moment what a grand will or will not buy. Then do what ya gotta do to go grab that amp!
Take it to a tech. |
Yeah... I pretty much have my sights set on buying it as soon as I can. Apparently, though, I've been doing some research and from various pictures/comparisons of the features it has (push/pull knobs for Solo and Shift, graphic EQ), it's more likely a Mark II of some kind. I'll take some pictures and get the serial number next time I'm there to be sure, but I was thinking it's in a little too nice a condition to be a Mark I.
Still... Sounds pretty damn good to my ears. I've always liked the idea behing the early Boogies, and this one even comes hot rodded with a cooling fan! |
Get a little falshlight and look up under the chassis, where the tubes are. There should be a date marked in black magic marker. That will start to give you an idea of which Mark II it is. If it's a MArk IIC, it's pretty much the holy grail Boogie, and $1,000 would be about half of what it's worth in great shape IMO. The Mark II B is a fine, fine amp as well, and $1000 would be pretty much in line with they are going for now.
If you like that sound, it's a solid score.
It's not that I lack focus, it's just that I'm musically schizophrenic... |
Technically Mesa never made a Mk I, they made a "Boogie".
When they added channel switching, they called that the "Boogie Mk. II". Note: if it has channel switching, it is not a "Mk I". The original Boogie design had two input jacks, one was the normal channel, the other was the hot-rodded "boogie" channel with the cascading preamps. You used one, or the other. After a while they started making a "Mk I. reissue". Original Boogies can vary a bit. The reissues are very consistent. There's not a real pricey vintage market for run-of-the-mill Boogies (as opposed to the Mk IIc). A good example of either is worth about the same, be it RI or original, if the options are the same (wattage, reverb, cabinet wood, etc.). For serial number dating, see this (they refer to Mk I's from the 70's because that's become the standard naming): Mark I 1x12: A0001-A2999 = 2999 Mark I Mark I 1x15: B001 - B300= 300 Mark I 1971 to 1978 = 3299 Mark I's Mark IIA 1x12: 3000-5574 = 2575 Mark IIA Mark IIA 1x15: B301-B549 = 249 Mark IIA 1978 to August 1980 = 2824 Mark IIA's Mark IIB 1X12: 5575-11000 = 5426 Mark IIB Mark IIB 1X15: B550-1100 = 550 Mark IIB Mark IIB Series 300: K001 to K336 = 336 Series 300 Mark IIB August 1980 to May 1983 = 5212 Mark IIB's Mark IIC 1X12: 11001-12499 = 1499 Mark IIC Mark IIC/IIC+ Series 300: K337 to K422 = 86 Series 300 Mark IIC/C+ Mark IIC+ 1X12 = 12500 to 14999 = 2500 Mark IIC May 1983 to January 1984 & Mark IIC+ January 1984 to March 1985 : 1499+86+2500 = 4085 Mark III 1X12: 15000 to 28384 = 13385 Mark III Series 300: K423 to K500 = 78 1988 Special Edition Mark III 1X12: 001-100 = 100 March 1985 to February 1999 = 13563 Roughly 1000 Mark III's per year.
"I like a tune. I like a tune and a singer and a solo, and now more of the tune."--Ian McLagan http://www.myspace.com/travishartnett Pearce Amps Info Page |
#8 (permalink) | |
I own an '81 Mark IIB, chassis date 7/9/81. 60 watt, non-verb version with no graphic. Pull bright, pull lead (also footswitchable) pull gain boost, pull shift, single input, with footswitch input under guitar input, presence on rear. Serial number 5473.
#11 (permalink) | |
No effects loop?
#14 (permalink) |
I'm still trying to wrap my head around the idea of a Mesa product being "vintage". Not that they aren't fine amps, but vintage? I've got t-shirts as old as that company.
Higgy |
It does have an FX loop. Doesn't sound very good, but it's there!
#16 (permalink) |
FWIW, there are no original Boogies... MKI's or MKII's... that have two channels. THey are all cascading preamp circuits. Mesa agressively protected the patent on this circuit back in the day. And...there are "MKI's" with a single input with a footswitching input directly under it. I have had one, sold it and still see it. IT was ordered when Randall's wife was taking orders and it was built in the 'garage'....at least that is what the original owner has told me. IT is a 100-watter with reverb and graphic EQ. IT is also the only old Boogie that I have seen that has a factory installed bias adjustment pot on the board. IT's serial number is somewhere in the low 3,000's, IIRC.
#18 (permalink) |
If the serial # says A 804 - buy it!
it's the holy grail - as that would be Keith's Boogie. http://homepage.mac.com/mesaboogie/K...%20Boogie.html El Mocambo '77
#20 (permalink) | |
Moderator
...you're vintage! Tim
http://www.moodswingers.org |
| I am considering a Mesa Boogie F50... | Califatboy | Amp Central Station | 24 | December 5th, 2007 10:37 PM |
| Mesa Boogie Mark II and IV Question | Soupbone | Amp Central Station | 2 | April 19th, 2007 04:38 PM |
| Mesa Boogie DC5? | JDMX88 | Amp Central Station | 3 | April 9th, 2006 01:34 AM |
| Mesa/Boogie mark 4, 1=12 Mesa Cab. | youngguitarist | Amp Central Station | 1 | February 17th, 2005 04:30 PM |
| Mesa Boogie DC-5 Question | Red Planet | Amp Central Station | 0 | May 5th, 2004 11:36 PM |
