Old November 1st, 2009, 01:13 PM   #1 (permalink)
telecat33511's Avatar
1970 Ampeg
I just moved into a new place.
I've tested everything after the move and the studio is functional
About ready to track and fired up my amps
The Ampeg Vt22 is making sounds like when you put a jack in when the standby is off ...With nothing plugged into it !
I thought it was my strat jack, because it was loose
Nope -its the ampeg for sure
swapped guitars cables and amps
any ideas ?
power tubes ? preamp tubes, reverb tubes ?
cold solder joints ?
Thanks
telecat33511 is offline   Reply With Quote
Old November 1st, 2009, 07:40 PM   #2 (permalink)
Well first make sure the tubes are not loose.
Change the tube one at a time to see if you have a bad tube or tubes.
If you have a 2 prong plug try it the other way
Try another amp to make sure you have clean power
Let the Ampeg warm up with the volume down for a couple hours.
Sorry thats all i can think of until you start to pay a tech.
I don't need no I.D.,I know who I am,I'm Tommy Bolin!
Post Toastie is offline   Reply With Quote
Old November 1st, 2009, 08:43 PM   #3 (permalink)
Check!
CHECK:Change the tube one at a time to see if you have a bad tube or tubes.
CHECK:If you have a 2 prong plug try it the other way
CHECK:Try another amp to make sure you have clean power
CHECK:Let the Ampeg warm up with the volume down for a couple hours.
I'll try it all again to be sure -thanks
Old November 1st, 2009, 08:54 PM   #4 (permalink)
Groovey Records's Avatar
Try moving the pre amp tubes as well or replace with known good tubes.
be careful removing the tubes one may be cracked but probably just microphonic
Yeah but you should of heard what I was trying to play-Thelonius Monk
EnJoY ThE MuSiC
GrooVey RecOrds
Groovey Records is online now   Reply With Quote
Old November 2nd, 2009, 11:54 AM   #5 (permalink)
Careful - rubber gloves
Will do., Thanks Groovey
Old November 2nd, 2009, 11:09 PM   #6 (permalink)
Oldschoolwax's Avatar
My Gemini 22 did a similar thing with a dirty rocker switch after a period of non use and moving... best of luck, let us know what you find!
Matter cannot be created or destroyed, nor can it be returned without a receipt.
Oldschoolwax is offline   Reply With Quote
Old November 2nd, 2009, 11:32 PM   #7 (permalink)
Does it do this plugged into a different power source / different room?
Are all the tubes lighting up?
Does the amp have reverb? Is the pan ok?
3 Chord is offline   Reply With Quote
Old November 3rd, 2009, 09:14 AM   #8 (permalink)
Donnie55's Avatar
Could be some bad caps.
www.myspace.com/redtele2
If the music business was easy, then smart people would do it.
Donnie55 is online now   Reply With Quote
Bad recordings in 1970 Larry F Bad Dog Cafe 12 May 12th, 2008 07:05 PM
January 1970 Heather Anne Peel Bad Dog Cafe 87 January 14th, 2007 05:13 AM
1970 stratocaster? How to ID? ashtray Stratocaster Discussion Forum 4 February 21st, 2004 10:41 AM
1970 Jazz Bass for $500? inertian The BASS Place 12 January 21st, 2004 06:54 PM
1970 Telecaster Brass Saddles Telecaster Discussion Forum 6 May 23rd, 2003 01:40 PM
