Best el84 and 12ax7 tube make?
the two ive got on ebay are a set of electro harmonixs ones and a set of jj teslas.
i have a vox ac4tv and play blur and arctic monkeys and stuff oh and i have a baja tele. thanks |
IMHO Phillips really makes a nice EL 84
So does Mullard For me I try to get Mullard , or RCA 12AX7 depending on which type of amp YMMV
Yeah but you should of heard what I was trying to play-Thelonius Monk EnJoY ThE MuSiC GrooVey RecOrds |
JJ EL84 and Tung-Sol 12AX7 are what I use. Readily available. Consistent. Not expensive. And a notch above most other current production models in many people's opinions.
At this point in time, I don't really understand using NOS tubes for anything other than maybe rectifier. But that is just me and I'm probably in the minority on that. |
Many guitar players swear by JJs, and I have those in my Peavey Delta Blues. But I also have most the Electro-Harmonix tubes that originally came with the amp.
Both brands are good...and low priced. After reading certain Vintage Guitar mags., I also realize that Mullard and RCA might have great tubes, but I just can't justify spending the money for it when lower priced tubes will do just fine. Maybe my ears aren't as trained as others... |
Going from Current manufacturing EH to other New Sensor Re Branded Tubes to Hand Selected Tubes to Nos Tubes on 4 Fender BF Amps simultaneously opened up my ears and allowed me to hear the difference .
NOS tubes offr many selections of brand that are less expensive then the mot desired brands and still out perform and last many times longer then current production. My early 70's EL 84 Mullards were 180 a pair' Sylvania's $100, JJ $34 There is no free lunch
#8 (permalink) | |
Pay the extra $4-6 for mullards you wont be disappointed. Oh and FYI EH tubes are probably the worst production tube you can get, JJ's are much better and only cost $1 more for 12AX7's
It's true i've lost my marbles and I can't remember where i've put them |
#9 (permalink) | |
I've had exactly one failed tube out of hundreds Check out Eurotubes HTH
http://www.MySpace.com/EdMcLaughlin |
#10 (permalink) | |
A REAL Mullard is an extra $40-$60, or $100...I don't get hung up on "tube tone" any more. There are exceptions but generally, if the tube isn't microphonic or otherwise noisy and lasts more than a year I'm good with it, I don't care about the brand, where it was made, NOS vs current...JJ, Sovtec, rebranded all good.
a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence |
The mullards he is talking about are re branded New sensor same as the EH's
I can get mullard 12AX7 OS pulls that test 100% for $40 One good tube in the V1 position can make a dramatic change Look people pay exorbitant prices for all sorts of stuff. Its your value system. Spend a $100 or more on a stomp box, or $1000 on a clone amp, more on a true vintage. It doesn't make sense to me not to spend the time learning about the differences even between NOS tubes as far as tone is concerned. It is a remarkable bang for the buck IMHO one tube can make a big difference
i went from a reissue tung sol to a RCA i found (it was free!) on the V2 (OD channel) and it basicly sounded like i went from an 8'' speaker to two 12 inchers. it was just so much smoother and "bigger" sounding
Really good quality NOS tubes do sound great, but they are ridiculously expensive. I wouldn't change my RCA blackplates in my Super Reverb for anything, but they were free with the amp and if they blow I'd probably try to find a modern equivalent tube.
One tip from me is that if you have to go NOS search some down yourself. They turn up in all kinds of places. I have walked into trendy shops selling 50s and 60s kitch and seen a row of vintage electronics being sold as furniture. I looked into them and they had rows of old Brimars, Telefunkens, Mullards etc. One day I'm gonna get a tube tester and walk into one of those places and pop every tube up and buy the ones I need. I'm not joking I see flea markets, junk shops, auction houses all selling vintage tube electronics not realising they have tubes inside the stuff probably worth more then the stuff itself. |
#14 (permalink) |
I know this may sound counter-intuitive, but I have read from multiple sources that the cheapo standard grade Sovtek EL84 is one of the best sounding versions in current production. Reliability and lifetime may be the crud, but it supposedly has tone.
This is not to say that I personally recommend them, I have no amps with 84s so I can't post an informed opinion. |
Bigger.. I am sure someone will correct me but IIRC there are some (heavy metal?) players who prefer the gain of chinese tubes.
I went to order some Mullard 12AX7s and thetubestore.com is out of stock. Are these just rebranded reflektors or is there something that sets these tubes apart? (in otherwords is there a comparable substitute for the mullard 12ax7s?)
DISCLAIMER: Just because I said it doesnt mean you should do it. As always, wear your rubbers, probe with one hand, and make sure you have discharged everything. |
#16 (permalink) | |
If you don't want to go with these, I would then recommend the Tung Sol reissues. I actually like these more than the Mullards. I like the top a little more, and they sound a little more open. YMMV, Jason
"...the appearance is kind of a drag to me; i find it awkward that the pickguard just cuts off in a flat line above the bridge, and that there's a metal plate surrounding the tone controls.., but whatever." - Random HC Tele Review |
#17 (permalink) |
I went through Sovtec, Mullard, and JJ before I tried the new Genelex Gold Lion EL84. It was like night and day. I never thought I'd hear such an improvement in sound with just a tube swap. Rich harmonics, punchy, tight, and lots of touch sensitivity. I love 'em.
#18 (permalink) | |
#19 (permalink) |
This is a very subjective question. You could have narrowed the field by specifying either current production or NOS tubes, and further narrowed by specifiying amp make.
EH makes a fine production 12AX7. JJ/Tesla makes a fine production EL84.
Strat/Tele > PJr/BJr/V1512T |
| Blues Jr. EL84 to 6L6 tube mod | Middleman | Shock Brother's DIY Amps | 19 | June 6th, 2009 11:44 PM |
| Sovtek or JJ's - EL84 and 12AX7 | castpolymer | Amp Central Station | 8 | March 19th, 2009 05:47 PM |
| First tube amp.... el84 ? 6L6? Help | highntightinaz | Amp Central Station | 20 | December 13th, 2008 05:41 PM |
| tube tone importants- el84-6l6 12ax7? preamp tube vs power amp tube effect on tone? | evol04gt | Amp Central Station | 15 | August 30th, 2008 01:14 PM |
| Favourite EL84 tube? | kiwi blue | Amp Central Station | 43 | November 2nd, 2007 12:46 PM |
