Old October 12th, 2009, 02:09 PM   #1 (permalink)
Peavey 4-10 Classic 50 blowing fuses....
I've always been pretty comfortable working on Fenders and have a certain amount of tube knowledge, but this amp appears to be very difficult to service for the way it's put together. I pulled the power tubes & let it sit for an hour. The fuse held. Then I put the power tubes back in. After about 10 minutes, the fuse went. There's no underbias plate glowing in the EL-84's so what's to look at next?
pullchord is offline   Reply With Quote
Old October 12th, 2009, 02:36 PM   #2 (permalink)
fezz parka's Avatar
Sounds like you've got a bad power tube. Replace 'em.
Old October 12th, 2009, 06:32 PM   #3 (permalink)
IF you pullled only the power tubes, then the problem is in that section....bad tube, blown resistor, bad gulp! OT. Usually it is something simpler than the OT, but there is that possibility.
IF you pulled them all, then pull them all again and put them in one at a time starting with the first preamp tube until you find the problem.
VOX AC15CC Blowing Fuses JCMNelson Shock Brother's DIY Amps 6 October 28th, 2009 09:02 AM
Bassman RI blowing fuses Del Pickup Amp Central Station 26 June 26th, 2008 04:40 AM
new 5F1 blowing fuses TelZilla Amp Central Station 6 April 9th, 2008 02:31 PM
Peavey Classic 50 head is blowing fuses... fwpilotfan52 Amp Central Station 4 March 21st, 2007 04:15 PM
New AC30 CC1 blowing fuses Chris Truman Amp Central Station 3 April 22nd, 2006 01:07 AM
