Old October 11th, 2009, 10:28 PM   #1 (permalink)
Tube Scare
So at practice today got a weird smell coming from my silverface Deluxe, kept playing anyway. Turns out one of the power tubes was shot, the other one that had life left was flashing like a firecracker, and there was a sound coming out like a bull crashing around a china shop. Turned it off. Took it home and pulled both bad 6V6s out and replaced them with a brand new matched set. It is biased correctly to the stock tube set, with 6V6s. So far so good. Sounds back to normal. I'm just wondering if I just described a typical tube burnout because I can't risk the same thing happening again soon, I got gigs coming up. I've had a failing tube before I usually experienced a cut in volume and the unwanted distortion, but I didn't really this time. Theres no smell anymore and both tubes light up about equal. What do you guys think?
NealVossy is offline   Reply With Quote
Old October 11th, 2009, 10:37 PM   #2 (permalink)
patrickhowell's Avatar
You should check the solder joints on the tube socket for the one that wasn't redplating. If one tube fails, then it will ruin the other tube if you keep playing, but you might want to make sure it wasn't something in the amp that killed it.
patrickhowell is offline   Reply With Quote
Old October 11th, 2009, 11:08 PM   #3 (permalink)
tazzboy's Avatar
Check Solder joints as well the Screen Resistors to make sure they aren't going out as well.
Old October 11th, 2009, 11:18 PM   #4 (permalink)
It was gone over by a pro just three months ago, I've been playing the amp with the new tubes for a day with no problems so far. If this was anything internal going wrong, wouldn't it happen right out of the gate, with the new tubes?
Old October 11th, 2009, 11:26 PM   #5 (permalink)
I got the same good sound out of it all day today.
Old October 12th, 2009, 12:25 AM   #6 (permalink)
tazzboy's Avatar
How long was it in the shop for?
Old October 12th, 2009, 01:29 AM   #7 (permalink)
It was in for about 3 days getting a physical. I got no red flags, everything is set to stock. Caps were good. Biased to 6V6s.
Old October 12th, 2009, 03:04 AM   #8 (permalink)
rangercaster's Avatar
if your tech says it's OK, i hope you trust him !!! and Go OSU Beavers !!!
"Work is the curse of the drinking classes."
Oscar Wilde
Old October 12th, 2009, 03:59 AM   #9 (permalink)
I got all these Oregon players responding, I love it.
Old October 12th, 2009, 05:21 PM   #10 (permalink)
tazzboy's Avatar
It could have been a bad tubes. If works just fine and doesn't have any more problems the continue on making beautiful noises.
PS GO DUCK!.
Dog Scare JPark Bad Dog Cafe 22 March 9th, 2009 03:45 AM
Big scare today. Am I all done? Telenator Telecaster Discussion Forum 51 June 8th, 2007 03:23 PM
Had a scare (way off topic) neocaster Bad Dog Cafe 5 December 16th, 2006 11:55 PM
A little scare ye olde fretmonkey Bad Dog Cafe 11 December 3rd, 2006 12:20 PM
Does This Guys Scare You pohorsky Bad Dog Cafe 11 May 16th, 2006 01:56 PM
