Old May 14th, 2004, 07:47 AM   #1 (permalink)
whats the difference...
Ho...between a series and parallel loop?...other then the obvious....brief primer anyone?...later, spyder
I'm not a luthier, but I used to play trombone with my jr. high band
spyder is offline   Reply With Quote
Old May 14th, 2004, 09:08 AM   #2 (permalink)
Teleologist's Avatar
Assuming you mean FX loop, Parallel means there's a mix control on the amp to control the wet/dry mix(the dry signal stays in the amp). In a serial-loop all of the signal is bypassed to the FX loop. Whatever is connected may have it's own mix control.
Keep on Twangin'
Teleologist is offline   Reply With Quote
Old May 14th, 2004, 10:10 AM   #3 (permalink)
Ho...thanks for the reply man..this amp I have has trim pots for send and return...adjusting them up or down affects the entire signal...shouldn't a parallel loop only affect the wet signal??....anyway, I like the sound of the parallel loop...my delay is digital ...seems like the overall sound is a little warmer using the parallel loop compared to the series thing ( the amp has both)...also, when using the parallel loop, should the effect unit level be maxed??...seems like I heard that somewhere...thanks, later, spyder
