Peavey Classic 30
Well, I had been jonesing for a tube amp for some time and finally got one. MandyMarie and I are buddies and she called me up saying that one of our mutual friends was selling a couple amps...one being a Peavey Classic 30. She and Danny both said that it was a great amp with decent power. They forewarned me that Peavey reverb isn't the best in the world but it will most likely suffice.
Well, I got a good deal on it I think and brought it home. It is really nice and definately a step up from the Vox Pathfinder 15T (that I still love...for a solid state). I am getting some of the hum so I have researched a little and have considered changing the speaker. Everything on this amp is stock, btw. Well, that's all...I just wanted to give you my review. I'm now keeping my eye out for a Peavey 112E.
insert witty and profound signature here |
hum
just to save ya some money; make sure all the tubes are seated properly in their sockets (unplug the Amp,
wear sneakers and use one hand, better still have Mandy or Danny show You how the first time). Nice Amp by the way 8) .
Somebody Loan Me A Dime |
PCB and board mounted tube sockets and pots aside, it's a workhorse li'l amp for sure and I do like mine. I swapped the tubes for all JJ's, added a tube guard and a tube tamer. I'll be swapping the speaker for a Weber ceramic Blue Dog, and make an extension cab for the stock speaker. I'm not a fan of reverb, don't use it, but the C30 reverb isn't as bad as some. I like the clean channel and the OD channel is one of the smoothest around, IMO. YMMV.
thanks for the info and any other tips to help improve the quality are greatly welcome. I played through it for 3 hours straight just tinkering with the sounds I can get through it (combined with my pedal setup). I think a majority of my hum is coming from my Danelectro ReelEcho pedal that is on a daisy chain power link...and I can't get rid of my Echo pedal...so I'll have to see what I can do. Thanks again
rob,
my stock Classic 30 is ready for some updates - did the new tubes, speaker make much difference in sound? where does one order a tube tamer? I love the clean sound of my C30 when I start pushing it hard - just wish it wasn't so Loud ( yea, yea this old geezer wants to turn it down ). 8)
all I need is just one more guitar :) |
#6 (permalink) | |
#7 (permalink) | |
bongo wrote:
I first put in J.J.'s tubes which really improved the sound, but I also had to bias the amp for the new tubes (they ran too hot and were burning out). I then put in a Weber California, and after 6 hours break-in using my home stereo, sounded so sweet (not harsh like the stock speaker). I also did Steve Ahola's Blue Guitar tone circuit mod which gave more bottom end and took out some of the harshness. This is a really nice amp now and I gig with it regularily. The Tube Tamer is available at: http://home.bellsouth.net/p/s/commun...pid=192273&ck= It really did fix the tube rattle. The Tube guard is also a really good idea: http://www.geocities.com/c30guard/ IMHO, the new tubes, biasing and tube tamer are necessities with this amp.
The smoker you drink the player you get~Joe Walsh |
Those Peavey Classic series amps are the sleepers of the amp world. I'd probably have one if I didn't have 3 Peavey Bravos. I'm sure I'll get one anyway. The local Peavey dealer has one on clearance for $380 or less. It's been there for at least two years, but what to they expect when they hide all of the Peavey stuff in a corner?
Peavey Classic 30 problem
Hey folks,
I posted recently about this amp squealing at anything above 8-9. Swapped out the pre-amp tubes. Problem solved, must have been a microphonic tube. Now, I have another problem. When i first turn the amp on from cold it will create a loud rustling noise, with some buzzing and crackling. I turn down the volume, wait till its warm and its ready to play with no noise after a few minutes. The fault only occurs when the amp is cold, and is intermittent. Seems to me the problem is internal? Its off to a tech isn't it? May not be worth fixing? Amp is a '94, and has been a trusty companion since then - one of the first Classic 30's. Ah, never mind me. I am rambling, and frustrated. Such a good amp for so long....one annoying thing after another now... Cheers, Adam |
#10 (permalink) | |
Valve seating...
#11 (permalink) | |
Re: Peavey Classic 30 problem
I read somewhere (maybe the owners manual?) that one should let an amp (especially a tube amp) set awhile & get up to room temperature before turning on - maybe try that first - it's free!
I love mine...
I traded my Blues Deville for a Classic 30 after I started to get out and gig. I wanted something lighter and easier to lug around. I love this little amp. It's got a nice smooth tone that I couldn't seem to get with the Deville (it was a 410). I use a boss blues driver for overdrive as I have not got a footswitch. I think the reverb and the overdrive channel are okay as well. I am going to order a new set of tubes soon from eurotubes.com, a tube tamer and a tube gaurd as well. You can't go wrong with the Classic 30
#14 (permalink) |
Well, I think I'm going to change the stock EL84's to JJ's, and maybe the pre-amp tubes as well while I'm in there. Have it rebiased since I have no earthly idea what I'm doing in there and don't want to screw up my first tube amp.
I'll get the guard and tamer as well for some preventative medicine. I'll most likely upgrade the reverb tank while it's being re-biased...the reverb isn't the best (though adequate) but I want to it to be ideal. Thanks all. Any other tips for dealing with my amp are greatly welcome and keep your eye out for a Peavey 112E...i think I want one of them.
Hey Lightnin,
I don't think you have to re bias your Classic 30. They are self biasing. Here's what Eurotubes.com suggested for me. "go with a matched quad of the JJ EL84's that are a #35 and three of the JJ ECC83S preamp tubes. These will smooth out and thicken up the drive channel and give a nice warm clean tone with a lot of sparkle. I would use a balanced ECC83S in the phase inverter hole which is the preamp tube that's closest to the power tubes ( the one on the left when looking at the back of the amp ). This will eliminate any phase cancellation or dead spots. These tubes would be plug and play with no bias adjustment necessary." I gave him a description of what I was looking for, mostly clean headroom. Anyway, good luck with your new amp |
#16 (permalink) |
What Mark just posted - it's cathode biased, not fixed. Talk to Bob at Eurotubes and tell him how you'll be using the amp and he'll set you up with a properly matched set of JJ EL84's. IMO, it's well worth changing out the preamp tubes to JJ ECC83S 12AX7's, too.
#17 (permalink) | |
I did just that
All those who believe in psycho-kinesis, raise my hand ! |
#18 (permalink) |
Thanks guys...I'll certainly talk to Bob when I get my tubes. It's good to know I don't have to re-bias it....I pretty much would've taken to a shop for no reason at all. I'm still going to look for a better reverb tank. If anyone has any suggestions (and links), they are more than welcome.
#20 (permalink) | |
