How stupid is this idea?
I have a small amp with a 10" speaker and a 12 will fit.
Of course, I'll have to make a new baffle board, etc. How much of an idea will I get for how the 12 sounds if I just pop it in and have it blowing through the 10" hole? I think I'll try it, but I won't know for sure till tomorrow...too late to crank it up tonight. |
I have a 15" in a 12" opening. But it is in a Bassman 212 DIY cab with lots of real estate for the drivers. You may want to blame it not sounding good on the smaller hole when in fact IMO your limitation will be cabinet real estate, of lack there of. Good luck though.
I would also mention if the existing baffle has threaded studs and nuts, you will poke hole in a 12, do not want to do that. |
I'd first try the target speaker patched in from a separate cabinet that is properly sized for a 12". If that sounds promising, I'd make a baffle board for the 12" in the combo cab, but I'd mount it and try it before I went to the trouble of finishing that baffle board with speaker cloth.
Even if the existing baffle board doesn't have studs for the 10", I would be concerned the smaller hole size would affect the sound negatively. And I would be concerned whether the cabinet real estate is sufficient, as Hackguitarist noted. So having (and trying it first in) a properly sized cab, will give you the information you need to determine whether the end state of having the 12" in the cab made for the 10" is good. I put two 15" speakers in a 2x12 Bassman cab by making a new baffleboard. It was okay but I went back to the 2x12 configuration for now, and I rarely use that cab anyway. I fancy some day making a baffleboard for that cab for a single 15 in the center, and comparing between the 2x12, 2x15 and 1x15. |
#6 (permalink) | ||
If we never tried something because it seemed to be a "stupid" idea surely we'd fall off the edge of the Earth and be eaten by dragons!! |
