Old May 4th, 2004, 05:03 AM   #1 (permalink)
Telecaster65's Avatar
Troubleshooting a Champ
Hi everyone,
After having completed my first amp project, I have these (small I guess) issues:
The situation is this:
The amp turns on nicely i.e. the tubes show a pretty orangish light, the speaker a very low, almost imperceptible buzz... but this buzz doesn't grows as I increase the volume. By plugging a cable and touching the jack edge, you may detect a higher noise, but this too does not increase with the volume. Tried to plug a piezo pick up but no sign of life (low hum apart)...
What could be wrong?
Thanks anyone replies...
Sleep tight, my child, sleep well
For I'll be at your side
That no shadow, no darkness,
no tolling bell,
Shall pierce your dreams this night
Telecaster65 is offline   Reply With Quote
Old May 4th, 2004, 11:55 AM   #2 (permalink)
Tim Swartz's Avatar
It could be a disruption anywhere. I would start w/ the tube voltages (plates and cathodes), and if voltages are OK, a signal generator and scope would be next. If you don't have a scope it will just take longer as you need to verify the integrity/accuracy of each connection. Luckily it is a Champ, so you are only dealing with a few components.
Old May 4th, 2004, 12:05 PM   #3 (permalink)
BrianF's Avatar
check and double check
every connection. Also check that all the grounds are actually making contact. Check all signal path, power, grounds, filament circuits etc. Look for poorly soldered joints, make sure jacks and switches are connected correctly. Be methodical and check schematic and layout section by section. A tube could be bad too...
Old May 4th, 2004, 12:08 PM   #4 (permalink)
Maybe I've forgot to ground the leftmost volume tang.
This evening I will try to star ground it...
Thanks!
no tolling bell,
Old May 4th, 2004, 01:36 PM   #5 (permalink)
Tim Swartz's Avatar
My suggestion is that you locate/fix the current problem(s) before moving on to a new grounding scheme.
Old May 5th, 2004, 05:47 AM   #6 (permalink)
Thank you Tim, a couple of grounding was missing. Now it works, even if..... Jeeez! He's noisy!!!
Thanks you all
no tolling bell,
