Musicmaster Bass amp arrived!
Just got my MMB this morning. I love the tone, it is the 6aq5a version. Changed the power tubes that were in it for some GE 6005, which improved the tone and output. I also experimented with some different preamp tubes a JJ ecc81(12at7), an EH 12at7, and an EH 12ax7. The 12ax7 was a little too dirty and a little bit louder. The EH 12at7 sounded good with sweeter overdrive but was a little too bright. The JJ ecc81(12at7) was the best to my ear it provided a smoother, sweeter overdrive that was nicely balanced and not overly bright or dark.
Can't wait to get a weber ceramic sig 12B and put in it. The stock square magnet CTS sounds pretty good in the one I have, you can tell it is distorting a fair ammount though. Will the volume really increase significantly with the new speaker? BTW, this thing sounds incredible for lead with a clean boost from my OD-3. |
Mine is nice and quiet. Hope it stays that way. Just got through jamming with my SR18 drum machine the amp performed very well. I really really like this amp, it sounds great straight in and it handles what pedals I have thrown at it so far really well. I have used it with a Little Big Muff Pi and a Boss OD-3. Tommorrow I will try it with a delay pedal in a band setting.
Good score. Just got the same model myself. The stock speaker was surprisingly nice sounding but, far too quiet.Not much hum. I put an Eminence legend 125 in there and, BOY, the volume increase! More clean headroom and blistering O/D. No pedals required (well maybe a bit of verb) Put an AY7 in the pre amp and the tone is fat and rich. These are real undiscovered treasures. I could probably gig with this little beast. Sounds a lot like a tweed. Telefiddler did you try the second input? I thought to maybe use an a/b box to get a clean channel and an overdrive channel
Ian
If it aint broke.....break it anyway!!!! |
Yeah, I tried both inputs. They both sound really good. Have you tried an AT7 in it to compare to the AY7? The amp definitely has a tweed vibe to it. I intend to gig with it as my main amp, may even get a 6v6 version in the future and run them stereo:)
The amp came with an AT7 but, it was a little too aggresive when it was dimed so, I tried the AY7 and can get some fairly decent headroom out of it. I think the speaker change is the most important factor. Im really impressed with this little amp but, would also like to try the 6V6 apparently its slightly louder and a bit more fendery.Let us know how it turns out on the gigs you do
Ian
Sounded good in a band setting, I can see how it will benefit from a speaker change, I had a lot of speaker breakup at about 7 on the volume.
It does use an 8 ohm speaker right? Also would it be possible to run out the second input and into another guitar amp? Last edited by telefiddler; July 4th, 2009 at 02:40 AM. |
Nice! The honeymoon continues...For fun I put a C12K in mine for a bit...good out put there, yeah! Changed it to a CTS AlNiCo finally. I have the Silver skirted knob one also, '74. So simple and now I understand that "simple circuit" love around here.
Here is a belated CONGRATS to you! Somehow I missed the thread a few days ago.
Congrats on the new amp :)
-- I constantly have to remind myself I'm a grownup and it's just the internet. |
#11 (permalink) | |
Think these things MUST have good efficient speakers in them. Takes all the middyness away. Mines a Eminence 125 and.....it loves it. I can get it nice and loud without it breaking up. 75 watts might be a bit overkill but, it seems to work. And, yes, its 8 ohm :) I love mine.
Thanks JohnnyCrash.
Doggy, Yeah it was loud enough in a band setting. But, there was a little too much speaker breakup for my taste with the original speaker. Haven't tried it in a band setting with the new Weber speaker in there yet, but will tonight at practice. I'll let yall know how it goes. :) |
#16 (permalink) | |
Guitar only also...it was apparently an entry level bass amp. Spartan control, V&T only, new speakers and a few choice mods (search TDPRI-tone mod) makes it a fun guitar amp. Has a SS rectifier. Two different model types, Fender changed the type of power tubed used in the mid seventies, 75 IIRC. Lite wieght amp. Rob D. talked these up apparently and was blamed/credited with popularizing them and raising the prices also...as I remember...Got a pristene one for $230 at GC. Tightened the tube sockets and voila...sounds great. And a low watt, (12) amp with a 12 that is lite to haul! |
#17 (permalink) |
I am only using this amp for guitar. It is an incredible sounding amp, the difference with the new speaker is amazing. The amp had no problem keeping up in a band setting and I only had it from around 4-6 on the volume knob. Before, with the original speaker, I had it up to 7-8 and still wasn't getting as much volume as I was on 4 with the new speaker. The speaker (weber sig 12b) sounds great too, excellent sound quality. It really brought the amp to life, I love the thing, it is my favorite amp.
#18 (permalink) | |
very cool to hear...do you have reverb or trem thru it? Weber sig12b info: "General purpose medium power ceramic 12. Economical replacement for Chicago Jensen C12N, C12Q, Oxford, Utah, Eminence, etc. 12", 40oz ceramic magnet, 50 watts, 1-1/2" voice coil, British cone and dust cap. Later breakup, strong low end with lots of punch and dynamics." Sounds like a good economic solution... |
#19 (permalink) |
Sweet! I'm on my second MMB. I dropped an eminence red fang in. A substantial volume increase came with it and with a recommendation from a forum member I put a 12au7 in to tame the volume and sweeten up the distortion at higher levels. Highly recommended.
#20 (permalink) |
Congrats!
I have the 6aq5a version as well. I've had it for 20-some years. A few years ago tried a few mods I ran across on the interwebs (clipping a resistor, swapping a cap or two--don't exactly remember) and I put in a Warehouse Vintage-Cele-type speaker. Kinda ordinary Fendery at lower setting (not a bad thing), but when it's turned up loud, it sounds awesome--a really sweet lead tone. Didn't think it had it in 'er.
_____________________ _ _ _ _ _ _ _ I should be practicing... |
| Musicmaster Bass Amp (MMB) - questions... | benhenny | Amp Central Station | 3 | March 9th, 2009 08:21 AM |
| Mods for my Musicmaster Bass Amp | JimmyZ | Amp Central Station | 25 | November 16th, 2008 10:06 PM |
| about those old MusicMaster Bass combo's | popthree | Amp Central Station | 49 | November 9th, 2005 06:37 AM |
| musicmaster bass amp | JOHNNY FOWLER | Amp Central Station | 2 | August 2nd, 2005 07:13 AM |
| And just WHY don't I have a Musicmaster Bass amp yet? | Honga Man | Amp Central Station | 7 | September 22nd, 2003 05:31 PM |
