Valve Junior Transformer Replacement?
I blew the transformer in my Epiphone Valve Junior Head (Version 3). I want to replace the transformer, but am wondering if an upgrade is possible without spending the $300 on a Mercury Magnetics set.
I've found this transformer, http://store.triodestore.com/tf65wscta48opaper.html , and am wondering if it would do the trick. I need a transformer with three outputs (4, 8, and 16 ohms), and as this states it is for an amp "...less than 25W...", can I use this transformer in my amp? I'd hate to blow it up again! Any other recommendations for a good transformer for a VJ on a budget?
Tele/Strats/Firebird->Huckleberry Fuzz->Pitchblack->Crybaby->Timmy->Analogman TS9 (Silver/808 mods)->Keeley SEM/Ultra DS-1->CE-2->Cool Cat Vibe->Small Stone->Outlaw Supply Big Blue Tremolo/Boost->Ibanez AD-9->Eventide TimeFactor->Marshall 1962 RI w/ KT66s |
check out the hammond 125e se works fine for me and sounds really good too.
http://angela.com/hammond125seseries...nsformers.aspx |
I looked at the link, what are the differences between the 125 _ se, _ being A to F ?
Can you purchase just the out tranny from MM's? Probably still not worth the money though. We bought a Hammond from Angela, and they are quite an improvement. Your link looks promising also. There is a power rating increase with those Hammond's. I am sure it is spelled out in the specs. Enjoy your new iron.
Good Luck |
Different power handling capabilities. Click on "more" button. B is 5watt C is 8 watt D is 10watt I'd go for C or D D will get you better bottom end
_____________________________________________ "no complaints yet, but it's still early"!!! |
SO if the bigger is better, why not choose E or F?
i pulled mine last night just to check. it,s a "c" not an e the c bolts right up but is 8 watts. this is the link to the e http://angela.com/hammondoutputtransformer125ese.aspx
| 5E3 Valve Junior | chabby | Amp Central Station | 8 | July 5th, 2009 01:21 PM |
| got an epi valve junior | WYfish | Amp Central Station | 5 | January 4th, 2009 03:41 PM |
| Replacement power switch for Valve Junior? | voided3 | Amp Central Station | 0 | November 28th, 2008 12:46 AM |
| Valve Junior and JJ EL-84 | tommyc | Amp Central Station | 14 | January 1st, 2008 12:43 AM |
| Replacement Transformer for Vox AC15? | CIM | Amp Central Station | 11 | June 10th, 2006 12:34 PM |
