Can I bridge channels on a DRRI? - Telecaster Guitar Forum
Old June 17th, 2009, 07:04 PM   #1 (permalink)
I don't know why I couldn't but I don't want to do any damage. Thanks
cdc3jj is offline   Reply With Quote
Old June 17th, 2009, 07:17 PM   #2 (permalink)
You won't damage anything, but it doesn't work real well. The Vibrato channel has one more stage than the Normal channel so they are out of phase with each other. You might find some settings that work, but you'll also find spots on the volume dials that will decrease the volume due to the phase cancellation.
Again, you won't hurt anything if you experiment with it.
milocj is online now   Reply With Quote
Old June 17th, 2009, 07:19 PM   #3 (permalink)
Guns1rose's Avatar
Yes, you can jumper the two channels. However, the two channels are out of phase, so you'll need to invert the polarity of the jumper cable, or buy a Barber Launch Pad...
Tyler Foxwell
Myspace.com/TylerFoxwell
Guns1rose is offline   Reply With Quote
Sponsored Links   #
Old June 17th, 2009, 07:27 PM   #4 (permalink)
TB72's Avatar
I do this with a Barber Launch Pad pedal. It has positive and negative outputs, which enables you to jumper the channels and get a bigger sound. Without the pedal, jumpering the channels causes quite a thin tone because of the phase cancellations...It won't damage the amp, but the tone ain't any heck.
Later...
Why is easy-listening music so hard to listen to?
TB72 is offline   Reply With Quote
Old June 17th, 2009, 08:10 PM   #5 (permalink)
Ok, that's cool. I was really digging the first channel and wishing I could have the reverb on the first channel without doing any more mods. Is there a way to do it without spending $139? I don't know much about polarity outside of speakers. (prepare for a stupid question here...) Can you swap it like you swap it on a speaker? Reverse the leads? Like take the hot and ground from one end of the cable and reverse them? Or am I going to get smoke and a repair bill? Thanks
Old June 17th, 2009, 09:13 PM   #6 (permalink)
holgaguy's Avatar
This out of phase problem - is that just with the Deluxe? Seems to work fine with my Vibrolux.
holgaguy is offline   Reply With Quote
» Random Photo for Guests
Fiesta Guitar body
» Recent ThreadsGuests
Fender Logan Custom Guitars
