Old June 16th, 2009, 01:16 AM   #1 (permalink)
AC15 Preamp Tube Question
Hey, I posted this over at the gearpages so sorry for the double post.
I am looking for subtle, or not so subtle ways to take some of the bite out of my Vox AC15CC1. I have done the bright cap mod but still find the amp very bright, harsh at times.
I was wondering if anyone had put in 12AT7's or 12AU7's in the preamp stage to warm up the tone a bit. I know some people do this to increase headroom, but that won't be a factor for me as I will just change my master volume and volume settings. (I don't need more headroom or cleans, now I am running the master at 10 o'clock and the volume at 9 o'clock. I have plenty or room left on both those dials.)
I play through Tele's but they are modded. The twang is gone and has been replaced with HB's, P90's and mini's. I use heavy gauge strings as in 12-56's so the tone there is big, it just can get abrasive...at least to me.
Thanks!
s360guitarist is offline   Reply With Quote
Old June 16th, 2009, 01:01 PM   #2 (permalink)
If you have the stock Wharfedale speaker, that may be what you're hearing. Try a Celestion Blue.
And what tubes do you have in there now- brand and type - all of them?
Old June 16th, 2009, 01:42 PM   #3 (permalink)
Thanks Wayne. I have received several recommendations to change out the speaker. While the blue seems obvious based on the Vox/Blue reputation, I could buy a lot of gear for the price of a Blue...maybe even a downpayment on a new amp.
Some have suggested the Cannabis Rex because of the way the hemp cone smooths out the harshness. Thanks for your suggestion...we will see what happens.
Old June 16th, 2009, 04:04 PM   #4 (permalink)
FMA
For the Blue vibe for fewer bucks, you might want to check out Eminence's Red Fang or Weber's Blue Dog. I have a Red Fang in my AC15 and it sounds great. It's a very efficient speaker.
Also, try maxing the master volume and controlling the overall volume with the regular volume knob. That's how I run mine and I get some pretty decent clean tones up to about 10 or 11 o'clock on the dial. Rolling back the treble, of course.
My amp is running JJ el84s and a Mullard 12AX7 reissue in the pre-amp stage. I use a JJ in the phase inverter. The Mullard just sounded better than the JJ to my ears. I've also had good luck, in other amps, with EH el84s.
FMA is offline   Reply With Quote
Tube preamp question... JG806 Amp Central Station 5 April 16th, 2009 07:03 PM
Preamp Tube Question RexGuitars Amp Central Station 11 January 5th, 2009 11:40 AM
Victoria 45410 preamp tube question Pickalittle Amp Central Station 13 November 29th, 2008 04:38 PM
SFDR Preamp Tube Question Robsocal Amp Central Station 4 October 21st, 2008 07:16 PM
Maz 38 preamp tube question... rcrecelius Amp Central Station 0 September 13th, 2004 08:09 PM
