Old June 13th, 2009, 12:36 AM   #1 (permalink)
scoots's Avatar
JJ/Tesla ECC832/12DW7 (what is this?)
this jj/tesla preamp tube is listed at the tube depot as half 12ax7 and half 12au7. how does this work? anyone try one of these? results? wwhhaatttt????crazy talk people.
...took the tube out of the v1 spot and replaced it with a dilithium crystal (like on star trek)...
scoots is offline   Reply With Quote
Old June 13th, 2009, 12:45 AM   #2 (permalink)
tazzboy's Avatar
I've used that tube. It suppose to smooth out your distortion some.
Old June 13th, 2009, 10:09 AM   #3 (permalink)
It depends on where you use it. 12AX7 half is a high-gain preamp. The 12AU7 half has only 20 percent of the gain, but can supply much more current--it's really a driver, but can be used in preamp applications. Ampeg used this tube as a driver for some of its more powerful amps.
Hot Rod Deluxe owners who find the Drive channel a bit much love this tube in V2--it decreases the crunch to more reasonable levels when you kick in Drive/More Drive.
The tube is a complete waste in V2 in Blues Juniors or Blues Deluxes because that stage of the tube is dormant--not used--so the amp just sees the 12AX7 half.
If you put the tube into V1, it does delay the onset of distortion and the maximum amount of distortion available, but it does not increase clean headroom. The loudest clean tone is the same either way--that's determined by the circuit, not the tube.
If you use a 12DW7 in a long-tailed phase inverter, it drives the output tubes unequally, creating distortion. Harp players often do this so they get breakup tone at loudness levels below the feedback point.
The 12DW7 is also a good choice for cathode follower positions because the 12AU7 half has very low internal impedance and can deliver buckets of current to the next stage.
Billm is offline   Reply With Quote
Tesla synthesizer Larry F Bad Dog Cafe 4 May 9th, 2009 07:53 AM
12DW7 Brown Deluxe Jammin'John1 Amp Central Station 3 April 30th, 2009 11:46 AM
Pro Jr - JJ Tesla Tubes?? studio1087 Amp Central Station 13 January 27th, 2007 10:02 PM
Would Tesla NOS EL84s... Charlie Bernstein Amp Central Station 6 September 20th, 2006 10:11 AM
6L6GC and 12AX7 from JJ (former Tesla co.) throstur Amp Central Station 3 December 16th, 2003 01:11 AM
