Correct schematic for Vibro Champ
I'm trying to bring a Fender Vibro Champ amp back to life. Its serial number is A609771, which apparently means it was built in 1976.
Does anyone know (or know how to find out) what the correct schematic number is for this amp? Thanks, Paul T. |
With the exception of the three-prong cord which your 1976 would already have, I don't think there were ever any changes to the Vibro Champ during it's lifetime. I think the two following schematics would be correct and the last one shows a Champ with a three-prong cord. I've never seen a later schematic than these two for the Vibro.
Vibro Champ and Bronco (same amp, different name) http://schematicheaven.com/fenderamp...a764_schem.pdf http://schematicheaven.com/fenderamp...b764_schem.pdf CBS era Champ: http://schematicheaven.com/fenderamps/champ_cbs.pdf |
I have a late 70s Vibrochamp..
There are differences between that and the BF and or the bronco. I will have to look but I think a) voltages in output stage are higher b) cap can may be 20/20/40 vs 20/20/20 cap. I will digg tonight after supper and find out.
DISCLAIMER: Just because I said it doesnt mean you should do it. As always, wear your rubbers, probe with one hand, and make sure you have discharged everything. |
All of those schematics are virtually the same. YEs, the voltages are higher in some compared to the AA764, but nothing else is different ...except for the CBS scheme. IN that one, there is a 330pf cap in the bais section that is not in the others. IN the 'Bronco' schematic, the first stage capacitor is a 40mfd. You can probably see that cap value in other real-life Champ/V-Champs due to availability of what was on hand at the factory. I would prefer the 40/20/20 as it would help keep the low end firmer.
Agreed, especially since the stock speakers were nothing to write home about. :)
| Fender Champ vs. Vibro Champ | 5stringer | Amp Central Station | 3 | November 17th, 2008 11:30 PM |
| Fender Champ/Vibro Champ questions.. | appar111 | Amp Central Station | 7 | November 6th, 2008 02:57 PM |
| 72 Deluxe vintage schematic or correct pots? | opiepac | Tele-Tech | 1 | February 1st, 2007 06:56 PM |
| Champ or Vibro Champ? what to choose? | Ivan | Amp Central Station | 12 | November 28th, 2006 01:03 PM |
| Champ - Vibro Champ questions | Jason S | Amp Central Station | 6 | August 28th, 2003 06:14 PM |
