Old April 3rd, 2004, 01:10 AM   #1 (permalink)
59 Bassman and the Radio Station !
Hey Guys
Sometimes I let my hair down and let the Bassman be cranked up and let lose !
When I do and have the lead placed into the input jack I start picking up the local radio station - wierd.
How do I get around this ? Shall we say that I do not need the competition !
Thanks in antipication.
Regards
Paul
Hipbluesman
Paul B is offline   Reply With Quote
Old April 3rd, 2004, 08:25 AM   #2 (permalink)
Tom A.'s Avatar
Haven't picked up a radio station yet but I have picked up a CB'er. Hey, a radio station isn't too bad, at least you can jam with it,
Tom A. is offline   Reply With Quote
Old April 3rd, 2004, 11:16 AM   #3 (permalink)
sunkidd's Avatar
I used to pick up Police calls with my '62 Bassman at a place we played often... at stage volume, it was kinda creepy!
sunkidd is offline   Reply With Quote
Old April 3rd, 2004, 11:53 AM   #4 (permalink)
Teleologist's Avatar
Have you tried different guitars and/or cables? Check that the actual shield on your guitar cable is connected at both ends of the cable. Some of the 'fancy' cables only connect it at one end and occasionally this can cause problems. Also check that the string ground is actually ground. You can also try turning the amp 90 degrees to see if it goes away. I'm assuming it's plugged into a properly grounded 3 prong outlet or whatever down under....
Is it playing a station you like??? ;) ;)
Keep on Twangin'
Teleologist is offline   Reply With Quote
Old April 3rd, 2004, 08:56 PM   #5 (permalink)
Hello all
The cable is a George L.
The amp is a home made 59 Bassman replica.
The guitar is a custom Robben Ford with Bill Lawrence L 465 Humbuckers and it is sheilded.
Does this help ?
Regards
Paul
Hipbluesman
Old April 7th, 2004, 05:39 PM   #6 (permalink)
bad ground before the grid of V1A....i'll bet my oscope on it...
"Progress is not possible without deviation from the norm." Frank Zappa
mark norwine is offline   Reply With Quote
Old April 8th, 2004, 05:18 AM   #7 (permalink)
Mark
Please explain in more detail. What is the "grid of V1A".
The solution would be to fix check and resolder the ground wires ?
Regards
Paul
Hipbluesman
