Old April 14th, 2009, 10:53 PM   #1 (permalink)
Scott S's Avatar
Inside a JJ 6L6GC.
Forum member Stuco (aka Patrick) was kind enough to send me the no-longer-serviceable JJ 6L6GC last seen in this thread. I've been longing to open up and study one of these bad boys, partly since I admire the robust construction of these tubes, and partly because I just enjoy looking at the insides of tubes.
Here it is. If you zoom in, the crack that killed this tube is close to the base, between my thumb and middle finger.
Finishing the job.
Next to one of my beloved metal 6L6's. These were rated at 19W max plate dissipation, while the JJ is rated at 30W.
Here I've trimmed off the getter haloes and grid cooling fin, so I can remove the top mica.
- Scott
"The chorus pedal is God's gift to the untuneable guitar." - Peter Holsapple
Scott S is online now   Reply With Quote
Old April 14th, 2009, 10:59 PM   #2 (permalink)
To bad you could not have gotten the glass off with a cutter of some type. It would have been neat to diagnose why they are so venerable to rattling so bad.
I have had a lot of problems with that in combo amps, and o-rings do not correct the issue. Its a shame, they are such a great tube..
EdMax is offline   Reply With Quote
Old April 14th, 2009, 11:04 PM   #3 (permalink)
Scott S's Avatar
Took me a while to get a decent shot down into the tube. You can see a goldish hue from the gold-plated grid wire.
A disencased 6L6G decided to join on the left. I absolutely love the ST-shaped tubes, but you can see that there was a lot of wasted space inside the bottle.
Here I've cracked open the welding on one end, to show the striptease view.
I measured the metal 6L6's plate at 0.007" thick. The JJ's plate is twice as thick at 0.014"! Check out those grid support rods -- they measure right around 0.049" in diameter! The bottle's glass is about 0.039" (1 mm) thick -- I measured it at the edge to get a more accurate reading.
Hope you guys dig it. I can take more pictures if there is interest.
- Scott
Old April 14th, 2009, 11:11 PM   #4 (permalink)
Scott S's Avatar
Just looking at them, you'd think they'd be pretty impervious to rattle -- the micas fit the glass pretty snugly in this tube, and it took some gentle persuasion to get the top of the bottle off. Once I took the top mica off, I noticed the cathode and grid rods were a little loose in the bottom mica, so perhaps that's where the problem lies.
- Scott
Old April 14th, 2009, 11:21 PM   #5 (permalink)
- Scott
You could be right!
Maybe its transmitting the problem to the glass.
I have resorted to replacing everything with =C= winged C tubes because they seem to be better supported.
One thing for sure, some of the JJ's I have never rattled, others more recently have been bad right out of the box.
Must just be a QC thing or worn out mica die.
Old April 14th, 2009, 11:35 PM   #6 (permalink)
Stuco's Avatar
This was (almost) a brand new tube. It was only used for a few days. As to if it was damaged in transit or installation or drunkeness I'm not sure. My guess is that it had a very small crack where the glass connects and it spread from there with a little pressure was applied when installing but who knows. I have since gotten another matched set so I have this broken one's partner as a backup.
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Old April 14th, 2009, 11:46 PM   #7 (permalink)
As a safety measure, read about Thorium and how to wash it from your hands. It's an Alpha Particle emitter that is or was often used on the cathodes and/or heaters in thermionic devices. You may already know this, and I'm not sure if Thorium is still used.
It's the same radioactive stuff that is on Coleman lantern mantles for some reason.
-Clint
Cleeve is offline   Reply With Quote
Old April 14th, 2009, 11:57 PM   #8 (permalink)
Scott S's Avatar
That's a good point. As an indestructible young guy , I probably don't think enough about the barium, strontium, and other rare earth elements I'm encountering. According to John Harper's page, thorium was used mainly on older directly-heated tubes.
- Scott
Old April 15th, 2009, 01:08 AM   #9 (permalink)
You're probably fine as long as you dont pull out the heater element and snort it!
It is interesting to open these things.. I wonder how much PCB I've been exposed to by opening capacitors to see how long the coil of aluminum is.
-Clint
Old April 15th, 2009, 03:31 AM   #10 (permalink)
eggman's Avatar
Howdy,
Informative thread. Thanks for posting, ScottS.
Eggman
eggman is offline   Reply With Quote
Old April 15th, 2009, 04:55 AM   #11 (permalink)
Very nice; thanks for posting
Jelle is offline   Reply With Quote
Old April 15th, 2009, 05:06 AM   #12 (permalink)
JohnnyCrash's Avatar
You could be right!
I LOVE Winged C 6L6's!
Every JJ I have/use seems to be pretty overbuilt compared to other brands. I dig em for 6V6's, but never took to em for 6L6's. I also have a pair of JJ EL34's that seem so-so.
I constantly have to remind myself I'm a grownup and it's just the internet.
Old April 15th, 2009, 11:01 AM   #13 (permalink)
LoveBandit's Avatar
Just as a data point: I love JJ Tubes also but I have had a few of them rattle also (this is when new) and it really bugged me. LB.
Everybody wants to save the earth; nobody wants to help Mom do the dishes.
-P.J. O'Rourke
Old avatar:
LoveBandit is offline   Reply With Quote
Old April 15th, 2009, 06:06 PM   #14 (permalink)
Same Here, This is extremely common of their 6L6GC's & their 6V6S tubes.
I buy a heck of a lot of tubes, and it seems to run about 75% rattle right out of the box (in combo amps).
I have a hard time finding that acceptable, but Damn they are fine sounding tubes otherwise.
TAD 6L6GC STR Tubes Anyone Know Em' lioncommandking Amp Central Station 3 December 22nd, 2008 05:38 PM
Winged =C= (SED) 6L6GC Review PraiseCaster Amp Central Station 15 July 5th, 2007 09:30 PM
Is it OK to use 7027A's in a 6L6GC amp? 145Guy Amp Central Station 8 May 29th, 2007 08:37 AM
RCA 6L6 Black Plate vs. TAD 6L6GC coyoteblue Amp Central Station 1 March 8th, 2005 02:28 PM
5881 vs. 6l6gc tele71 Amp Central Station 10 June 29th, 2004 11:20 AM
