Showman Head Troubleshooting Question
I have an early 66 blackface Showman head. I was playing it when the sound all of a sudden a sound started occilitating up for a few seconds and then it went dead. The fuse had blown. Any ideas of what happened?
| Sponsored Links |
Dead short inside a tube, maybe? Check the tubes themselves for any burn marks inside (outside of the getter flashes, which should be silver or turning white). Check the tube sockets for burn marks, in case they arced. And, I'm not sure what the output tranny should read as with a meter, but check that as well. One of the other guys here should be able to give you an idea of that.
The oscillation is a clue. It sound like the amp 'ran away' with ultrasonic feedback, causing it to eventually draw too much current through the power tranny. It may have toasted tubes, too.
This is a tech job, to work out what it is that is causing the problem - could be lead dress if any changes have been made recently. You may need to get the grid stoppers added to the power tubes.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
#4 (permalink) | |
Dacious, as you know more about these than I do... What do you think about him turning the amp on in the dark and checking the glow of the tubes? Something in my gut says, though, that you've got an internally mangled 12ax7. I had a 1965/66 DS myself and I had a single power tube suddenly redplate and I lost half the power, but the fuse never blew. Just replaced it with a matched quartet from Andy Ruhl and things were cool. Would the grid in a 12ax7 suddenly connecting internally to the plate cause enough current draw for the thing to run away? I by no means am any sort of expert (though I'm definitely trying to be :-D). Just tossing out a few ideas. |
I took a look ...
Thanks guys,
It has a matched set of Groove Tube power tubes. The big orange G on the first tube now looks like a big brown G. The second tube started looking a little brown too. So, either something toasted the tubes or the tubes toasted the fuse. I hope the power transformer is still ok. I guess I will need to take it over to my trusty amp tech and have him do an autopsy on it. Mike |
#6 (permalink) | |
Re: I took a look ...
If for some ODD reason you decide that it's not worth it for you to fix that (I would suggest that it is), lemme know... I miss my old DS and would love another one. :) |
Gilmour,
I'd be happy to let you know. I sell a lot on eBay and was actually thinking of putting this baby on the auction block. It was gone through by an amp tech a least a couple years ago. It is absolutely pristine with hardly a scratch. I was playing it through a cabinet with two 12" speakers of questionable ohmage so maybe ohms law stopped it for speeding. I will need to run it through a Showman cabinet next time. Mike |
