Old February 22nd, 2009, 10:49 AM   #1 (permalink)
Radspin's Avatar
Bandmaster Speaker Impedance Matching Question
I have a 1964 Bandmaster head. I would like to run it into a single 12-inch speaker (I have a 2-12 4-ohm small-box Bandmaster bottom I use for bigger gigs). I know the Bandmaster has a 4-ohm output. Here are my questions:
--How much volume would I lose when I run the head into an 8-ohm 12-inch speaker, as opposed to using a 4-ohm 12-inch speaker?
I know this may be hard to describe in specific terms, and is somewhat dependent on speaker efficiency--I'm just looking for a ballpark idea. Right now, comparing my closed-back 1-12 speaker cabinet with a generic Eminence to my 2-12 reissue Jensen-loaded Bandmaster cabinet, it seems like I'm losing about 30 percent of subjective volume. (I know this isn't an apples-to-apples comparison as I'm comparing a two-speaker 4-ohm cabinet to a one-speaker 8-ohm one; I'm just throwing it out there as an observation.)
--What 12-inch 4-ohm speakers are available and recommended? So far, I've only found the Eminence Texas Heat 4-ohm version.
--Will there be any long-term damage to my Bandmaster head if I run it at 8 ohms rather than 4 ohms? I think the answer to this question is "no," but I don't know for sure.
Radspin is offline   Reply With Quote
Old February 22nd, 2009, 11:35 AM   #2 (permalink)
Bluesbob's Avatar
No problem...
I ran my '64 Bandmaster head into a 1X15 cab for years, with no ill effect
You don't get any more power out of a tube amp with a change in impedance, so all you lose is the 3 dB from only having one speaker (all else being the same, which it never is).
I don't know anything about 4-ohm 12" speakers, but I do have Jensen RI C12N's in my Bandmaster cab. Maybe you just need a 1X12 combo?
What, me worry?
Bluesbob is offline   Reply With Quote
Old February 22nd, 2009, 07:43 PM   #3 (permalink)
Radspin's Avatar
Hi Bluesbob,
Thanks for the info. I also own 1-12 and 1-10 combos--I'm just trying to find a way to use my Bandmaster more without carrying around that 2-12" bottom.
If you also own a 1964 Bandmaster, I don't have to tell you how great it sounds!
Old February 23rd, 2009, 10:13 AM   #4 (permalink)
Singin' Dave's Avatar
Weber speakers are an amazing match for just about any vintage Fender and come in all flavors, sizes and ohm ratings. Highly recommended!
Singin' Dave is offline   Reply With Quote
