Carmen Ghia 2 x 10" combo opinions.
I just love my Carmen Ghia head through a 2 x 12" cab. I'm thinking of picking up a 2 x 10" Ghia Combo as a backup. Anyone currently have the 2 x 10"? How do you like it?
www.good-ear.com www.miles.be Study music and not the musicians who play it. - Lincoln Goines |
Hi man...I don't know if you remember my other thread...it was Ghia/Mazerati opinions. Anyway, I too am looking for a 2x10 Ghia, so I was wondering if you could tell me a little bit about your Ghia head???
What does it sound like if you had to loosely relate it to another amp? Around when on the dial does the amp start to break up (ie. 9, 10 Oclock)? I wonder why no one is responding to your thread..? Must be a slow week. Cheers!
...a little less conversation, a little more action... |
I've got a CG head that I've run through both a 2x12 (loaded with a v30 & a greenback) and a 2x10 (loaded with Celestion vintage 10's). Overall I like the tone of the 2x10 best; it's punchier with a bit more definition. Keep in mind that speaker selection plus the cab design (my 2x12 is closed back, my 2x10 open-back) also influence the role.
I guess my question is if you have a CG head that you love through your 2x12 and you want a back-up... why not just buy another head? It would save you some money. Personally though, I would opt for some other amp as a back-up because I like a little variety: A Maz Jr. or a GDS 18w Marshall is a great alternative amp that's still in the same realm. As far as what a CG sounds like: Hard to characterize but I would say that it comes closest to a low-powered Plexi. It's much more aggressive and in your face than a Vox. It's closest comparison is probably the 18w Marshall. It starts breaking up about 10:00 but stays reasonable "clean" (hot clean) until around 12:00.
MJ Harnish Suburbs: Where they cut down all the trees and then name the streets after them. |
#4 (permalink) | |
Dana
Thanks for the replies boys. Just a quick question or two;
The tone knob on the Ghia....does it have a big sweep? I know on my AC30, the Cut knob's sweep isn't that big, so I was wondering, does the amps tone knob really take a dark to bright tone, or is the amp already dark or bright, with the tone knob offering little variation? I like the simplicity of the controls....thats whats so attractive about these amps. Also, why isn't there a standby switch on the amp? Doesn't this burn out tubes faster? How long does it take for the amp to warm up, and do you have to leave it on in between sets when you play? Thanks again for your input... Cheers!!
#6 (permalink) | ||
Seriously, I love mine so much I'm thinking of getting a Ghia 2 x 10" combo on days I dont' want to carry the head and cab. It's a great amp.
Well I think I'm gonna take the plunge, and order a 2x10 Ghia combo myself. Now I just have to think what color I'd like. I'm leaning towards the blond tolex, with wheat grille....
I just hope its not going to get dirty. Also, I don't know if anyone can help me with this, but if I were to hook up the combo to a 2x12 cab, would that shut off the amp's internal 2x10's?? Cheers!!
Ok, lots of questions:
Tone Knob - It does have a pretty profound effect; it's not simply some sort of treble roll-off but more like a midrange control that moves where the peak is located. I generally just try to dial in my sound with each guitar. Volume Level - It's a pretty loud amp; 18w is quite loud so don't expect it to be a great bedroom amp. I have used mine live plenty of times. Standby Switch - The standby switch isn't necessary. The 5Y3 rectifier generally softens the turn on voltage a bit but not a great deal. However, standby is a myth in most amps: It got started because tube manufacturers recommended warming the tubes up before using them for high voltage applications to prolong tube life. HV was 800+V (generally over 1000). Tube amps operate at 600v or less which is a low voltage application. At that point cathode stripping is negligible; the tube is more likely to start sounding bad or fail for mechanical reasons long before cathode stripping has any sort of effect. If you want to prolong tube life use a fan: Heat is one of the top killers of tubes and amps in general and that's generally due to thermic cycling (repeatedly getting hot & then cool). Just turn your amp's volume down in between sets (only to keep it quiet). Using an extension cab; my guess is that you have to unplug the internal speakers to plug in an extension cab. That said, it seems poor planning to buy a 2x10 that you plan on using with a 2x12; that's twice as much stuff to carry in/out. Buy yourself a head in that case and then you can mix & match cabs as you like.
MJ....I just spoke to my dealer, and he says that you could run both the amps' 2x10, and 2x12's so long as you use the right ohm plug for the cab. I really don't see myself needing the 2x12's....I just thought how great would it sound running 2x10s, and 2x12's at the same time. It must sound huge. Thanks for your info....
I'm looking forward to buying one. Cheers!!
