can you have the ohm rating changed on a speaker?
if i want to switch a 15 ohm speaker to 8 ohms, is that possible? it would have to be reconed anyway, so i was wondering if i could have this done at the same time?
thanks
my band's myspace. featuring our new video! http://profile.myspace.com/index.cfm...ndid=261142458 |
Never heard of changing a speaker's ohms.
Get a new speaker - or an old one; just get one of the right resistance/impedance (or what ever the ohm geeks want to call it) for your OT!
It doesn't mean a thing if it doesn't have that twing! |
Moderator
Yeah, you're basically just using the basket and maybe the magnet, and building a whole new speaker around it. Probably cheaper and definitely easier to just buy a different speaker!
Tim
http://www.moodswingers.org |
Using a large enough resistor...wattage rating....you can wirein series or parallel with the speaker and attain a differeng impedance. I wondered about this after having a certain 8" speaker reconed and then realizing that it would fit perfectly...and might have come from a Gibson amp....but that it needed to be 8 ohms to work in my GA-30. I talked to TEd WEber, and he said that the above remedy would work....and so it did....and still does. I do wish that I had had the speaker reconed at 8 ohms, but I did it before I got the amp. For an 8" speaker, it has a huge magnet. The size of the magnet makes it proper for this amp. I have compared it to another GA-30. Someday I might have the speaker reconed at 8 ohms. Until then, it is working fine and yields the correct impedance when paired with the other speaker in the amp...a 12", 8 ohm.
i dont think you can use resistors to REDUCE resistance. hes talkin about going from 15 down to 8. resistors add resistance, so to go from 8 to 15, then yeah, the right resistors should work...
#6 (permalink) | |
Wired in parallel divides resistance/impedance (2 @ 16 ohms parallel = 8 ohms) So...wire a resistor of at least 15/16 ohms in parallel to the 15/16 ohm speaker (BTW speakers are never exactly 4/8/16 ohms... more like 3.7/7.8/15 ohms) and the effective rating will be 8 ohms.
"I'm not responsible for anyone's gruntlement" - Lt. Col. Henry Blake |
#8 (permalink) | |
I just had an 8 ohm JBL D130F reconed by Ted Weber for 4 ohms to run with my bassmen and Bandmaster Reverb heads. As I understand it, it's pretty easy to specify voice coil ohmage to whatever you want when reconing. This would be distinct from wiring multiple speakers to certain impedences.
And btw, you loose the same power no matter if the resistor is in series or in parallel. The resistor will dissipate half the power sent to the speaker/resistor circuit.
Back to practice now...to make my Teles sound good. |
I just re-coned some 16 ohm jensens to 8 ohms..Cane out great. I got the baskets fairly cheap. Ended up costing about 90 bucks per. I'd go that rout again in a heartbeat because they came out great. What is really important is who is doing the work and with what parts. I happen to have some repair guys around here who are crazy good, into what they are doing, and have the right parts...
