Silverface Deluxe Reverb...one better than another?
Is there a major difference between silverface deluxe reverbs from the 70's?
Is there a major difference between a '70 and a '75? Is there a year that is more preferable than another?
http://www.brianvanderark.com/ |
Mark, as long as it's PTP hand wired
don't sweat it, if you really have to "Blackface Mod"
it's elementary BUT I personally see no need whatsoever to me it's just being anal. You're working with one of the greatest if not THE GREATEST TUBE of the all, the fabulous 6V6. And when that thang is on "4" she's gonna sing you a tune you won't forget. A hand wired Deluxe is one of the "Grail Amps".
Somebody Loan Me A Dime |
'70 v. '75 Deluxe Reverb
The '70 will have a wood cab with a screwed in baffle board, while the '75 will have a particle-board cab with the baffle dadoed in. I much prefer the earlier cabs--they're lighter and the baffles can be replaced easily if necessary. Hope this helps.
Yeah but Doc
It's a Deluxe Reverb what's it gonna be 5-7# lighter?
His savings on a later year is gonna be 3-4 hundred. And it's still gonna sound great, a WORLD better than the current offering for sure. JMO (no flame intended, respect)
The price difference will not be that much, but the fact is there's really no sonic difference between BF and & *any* SF DR's, even the pull-boost models. "Blackfacing" a SFDR is a waste of money - invest in a cap job, good tubes and maybe a speaker change and they all sound pretty much the same (not the RI's however). BF's are for collectors, and the best buys are the pull-boost models. Sure, the bafles are different - but they make no identifiable difference in the sound. Proper amp setup is far, far mor critical with DR's than the minor design differences.
On pull-boost models, just don't pull the knob and you're in great shape!
“No Chops – Great Tone” © |
must agree
Just scored a sweet sf DeLuxe.Did a side by side comparison to a real live 65 BF.Mine is the SF with the pull/boost.The boost is a waste.But my Silverface actually sounded BETTER.Fatter ,Fuller.And the BF is EXTREMELY well maintained by a veteran pro.
Well I'll gently disagree. I have a 69 drip edge silverface DR I really love--I agree they are all good amps. But I A/B'ed it with a blackface 65 dr and the blackface sounded noticeably better--just not enough better to justify the extra dough to my cheap self.
As i understand it the silverfaces were changed to A; stay clean longer, and B: compensate for sloppy wiring. I've read that the transformers on the blackfaces were different. From what i have heard, blackface amps do tend to sound better, but as i said, for me it was not enough better to justify the way higher cost A good cap job and good speaker, good tubes will make a bigger difference than "blackfacing" the circuit, IMHO |
Gently putting my own .02 in as well...
Blackface DR's from the 60's and silverface DR's built in the 70's sound different to my ears. The circuit changed over the years and so did their sound. Hard to say how big of a sound difference, because everyone hears differently. But if you take a '64 DR and compare it to a late 70's, that would be the biggest difference if any. Which year is more preferable really depends on a person's tastes. I prefer blackfaces...best one's I heard belong to 2 friends of mine ('64 and '66). FWIW...I also feel different cabinet construction (pine, plywood, particle board) will effect sound. Edit: In regards to silverfaces, I prefer the earlier versions w/out the pull "boost" function. |
must agree with the man who disagree's with me.
"Better" sound is definitly in the ear of the beholder.
You mentioned that the SF changes were to help the clean sound hang on longer.I didn't know that,but it makes sense because thats the sound I use the most,so naturaly I thought my amp sounded better.But I'm guessing the difference in marginal and probably changes with speakers,tubes ,caps,guitars.Think its possible to get a combination of the compents to make the BF the clean one and theSF the "dirty" one,or is that difference just in the design of the two amps more"genetic".? |
70's SFDR's
They had some circuit changes during the early 70's but not many. The phase inverter input cap and the phase inverter plate and grid-to-tail resistors are about it from 70-75. My '71 had the .01 PI input cap which is not the BF=.001. However it had the "BF" resistor values. I changed the PI input cap to the .001 which would have reduced some bass (perhaps subsonic anyway) but I also switched from the crappy stock Oxford speaker to a Weber P12n. Woo hoo!
http://www.geocities.com/jjsant/SFDR.html Many people lie/fudge/are confused on the production year of the SFDR they are selling. Here are some cosmetic differences from 1970-75: 1970 Says "Amp" on front of face plate under word "reverb" stock 2 prong power cord stock bare shield RCA reverb cables "tail logo" 1975 No "Amp" stock 3 prong Common plastic coated RCA reverb cable no tail under logo Pull boost came out in June 1977 on SFDR's and it is a thick line to cross in "vintage" status and thus value. Can't comment on whether leaving it turned off is the same as a 1976.
JJman If it says "Vintage" on it -it isn't. |
More info.....
Lot's of good stuff here.
I did a lot of research before getting my 1976 SFDR. I also A/B'd it against a well maintained 66 BFDR. SFDR do not have particle board cabinets... its plywood. the baffle is particle board. I had mine blackfaced. I heard a difference and the $55-60 it cost me was nothing and I had the amp open for a cap job anyhow. IMO, the BF tone circuit is not as trebly as the SF. The amp distortion is also smoother IMO. The key to any old amp is how well it is maintained..... new vs. old caps, type and condition of tubes. and how you have it biased. Speaker also makes a big choice. I love the SFDR. It's a great value and you can tweak with speakers and tubes to get the tone and vibe you want. Don't worry about the pull boost on a post 1977. This can be easily disconnected. Buy a good condition amp. Try it out. If you like it leave it alone.... you can always up grade things as you move forward.... nice thing about PTP. Bob |
