Old February 9th, 2004, 11:13 PM   #1 (permalink)
Blond "Bandmaster" Head Question? Cab, ohms etc.
Hello, I have a Blond Bandmaster head..... I'm pretty sure it is a 4 ohm Transformer.( the Tube Chart has been painted over). It has a newer and larger kendrick's tansformer. I was told it is 4 ohm. so i'll stick to my story.
the question is , I need a cabinet... I will be getting one made. The earlier "Brown Tolex 3X10" Cabinet Crossed my mind. I imagine it would fit? Any make this cabinet (Correct Everything). I researched and found out the old (Tolex 3X10)Bandmasters had three 8 ohm speakers wired in parallel = 2.6 ohms!
Any why to get three 10 inch speakers closer to 4 ohms? I have Weber in mind.
would running 2.6 ohms screw up the transformer?
would it screw up the tone. Bad idea? any info and help would be great. thanks
BADFISH is offline   Reply With Quote
Old February 10th, 2004, 04:09 AM   #2 (permalink)
Pierce's Avatar
advise Ted of what you need and he will make it
probably a four ohm bassman OT. Fender used eight ohm speakers alo by the way. Do you know if the Ot is a multitap you could tell by sliding the chassis out or looking at the wiring coming out of the Ot (three on one side bl/brown/red-two on the outside green/black any more than two it's a multi) If it was a multi I'd use the 2 ohm tap and run three eights
Pierce is offline   Reply With Quote
Old February 12th, 2004, 05:01 PM   #3 (permalink)
Thanks for the info on the transformer (I'm about to check it out) I'm also Emailing Ted Weber and see what he thinks.
