Old February 3rd, 2004, 11:54 PM   #1 (permalink)
HRD line out
I'm shopping for a new amp and considering the Hot Rod Deluxe. Does it have a way to line out signal to a PA?..I play in chuch and the rest of the band has issues with miked amps...thanx
kihoalu is offline   Reply With Quote
Old February 4th, 2004, 03:07 AM   #2 (permalink)
mcfm2n's Avatar
Yes it does, I play in church also and use a HRD. I go from the preout to di box to PA system and use the amp as my monitor. This works very well and if the sound tech needs more signal i can give him all he needs. The only thing is that the preout is before the reverb and presence. Hope this help, the HRD is a good amp.
mcfm2n is offline   Reply With Quote
Old February 5th, 2004, 04:18 PM   #3 (permalink)
Do you have any complaints with the Hod Rod Deluxe??
smooth_picker23 is offline   Reply With Quote
Old February 7th, 2004, 09:35 PM   #4 (permalink)
mcfm2n's Avatar
HRD
No complaints at all from the other band members volume does not go pass 2.5 . I have been using the amp for almost 2 years now and i have had only one problem that got resolved by changing 1 preamp tube. I am even thinking about getting a second one so i can leave one at church and the other for the house and gigs.
Old February 10th, 2004, 10:07 AM   #5 (permalink)
TheGoodTexan's Avatar
Another option
If you're going have to buy a direct box anyway - get a Palmer DI. You can use it in conjunction with a preamp line out or even a speaker level output. It is the best direct box out there, and it is made specifically for guitar amps.
I use one between my amp and my speakers, and it sounds incredible. This way I get the presence and reverb included. I even used it in a praise band at a medium sized church for over a year. They usually run around $100.
Originally Posted by Sidney Vicious
If there's anything worse than whining its whining that your whining isn't being heard.
TheGoodTexan is offline   Reply With Quote
