Old September 27th, 2008, 06:58 PM   #1 (permalink)
67 Bassman making static-y sound when playing?
When playing through my 67 Bassman head, I get a pronounced static-y, distorted sound when playing chords, almost like the speaker is distorting (but it's not the speaker - I tried another amp through the same speaker and it's fine). I swapped in two other power tubes in the Bassman, but the distorted sound is still there. Any thoughts on the most likely causes for that particular symptom?
Thanks...
fenderfan is offline   Reply With Quote
Old September 27th, 2008, 09:18 PM   #2 (permalink)
Tele-writer's Avatar
Have you sprayed potentiometer cleaner into the controls recently? Mine did as you described yours doing and I found my cure in cleaning the volume controls thoroughly. A second possiblility is that one of the pre-amp tubes is verging on failure. Try tapping each one lightly with a pencil eraser with the volume up just enough to hear if the tube has gone microphonic. Good (and regular) maintenance is its own reward :)
I just love the smell of fresh strings in the mornin'
Tele-writer is offline   Reply With Quote
