Old September 23rd, 2008, 07:30 PM   #1 (permalink)
ccrnnr9's Avatar
weird popping noise from '73 Silverface champ
I recently purchased a used Fender Silverface champ and I like it a lot (although not sure if it is exactly what I want). The only weird thing is that within the last couple of days it has developed a small popping noise that starts once the amp is warmed up and the volume varies without touching the volume knob. For example I usually play with the volume at 2-3 and it will make the popping noise and the volume will turn down and slowly turn back up. Any clue what this could be?
~Nick
ccrnnr9 is offline   Reply With Quote
Old September 23rd, 2008, 07:37 PM   #2 (permalink)
Hoodster's Avatar
Is your wife opening beers in the next room?
Sorry, couldn't resist. As for your Champ, if it has not been serviced, it is long overdue. A 35 year old amp will need new caps, cap can, tubes, etc.
You can add dirt, but you can't add clean.
Hoodster is offline   Reply With Quote
Old September 23rd, 2008, 10:34 PM   #3 (permalink)
ccrnnr9's Avatar
First of all I am not married (thank god) so the popping noise is coming from elsewhere. As far as where I wonder why it would all of a sudden start when it has been fine otherwise until now.
~Nick
Old September 24th, 2008, 01:48 AM   #4 (permalink)
Gr8tfulEd's Avatar
Couple of basic things obviously:
1. Change out the tubes one at a time and see if that helps. The volume drop makes me think pre-amp tube. I had a tube go bad recently on my Twin Reverb and it had a similar volume issue. It was the first gain stage of the Vibrato channel.
2. Try a different wall jack.
If none of the above help, definitely find a good repair person (good to know this person anyway) and get it serviced.
"Music is not a competition. The best music is cooperative."- Jerry Garcia, Las Vegas 1993 interview
"[Expletive Deleted]"- Richard Nixon
Gr8tfulEd is offline   Reply With Quote
