Relay for channel switch in PTP amp?
I've been looking around on www.mouser.com trying to see if I see an appropriate relay to use for channel switching in an amp I'm building... I'm figuring I'd wanna use the 6.3VAC heater leads as power for the thing, and I didn't see too many that use a voltage that low. Is there a particular one you guys recommend?
If you use a voltage doubler, your choices for relays are many. *HINT* If you use a relay rated for 12VDC, you can be safe from slight low line-voltage situations.
"You can lead a horticulture, but you can't make her think!" |
finding small relays with 6V coils is not a problem...keep looking; they're out there. Omron, Fuji, Matsu****o....they all make them.
personally, i wouldn't use a realy for switching.....they're too slow. the "rise time" on the coil, added to the "transition time" is substantial in the world of audio....certainly detectable as a "dropout" during the switching. plus, if you don't buffer properly you run the risk of an annoying pop... personally, i'd do it with transistors, but...hey....i'm retired! i don't have to do it at all anymore!!!
"Progress is not possible without deviation from the norm." Frank Zappa |
what a riot!!
there's a large japanese relay maker named matsu...s.....h .....i ....ta...and 4 letters of the name spell a word that was *censored* by this software! Oh Well
#5 (permalink) | |
Sooo... Transistors... Mouser would have those, I assume. Any linkage to info on how to wire those in and which ones would be applicable? |
