Old January 22nd, 2004, 01:46 AM   #1 (permalink)
Cam
Cam's Avatar
back panel buzz on a blues deluxe
It is emanating from the metal serial number panel on the back of the bd when the amp is turned up a bit. It stops when I press on it with my hand .....so.....drip a little crazy glue on the edge of the plate and let it drip down between the panel and the metal? Or......what? Thanks in advance.
Relic Schmelic!
Play the darn thing! Wipe it down after and put it in it's case!
Cam is offline   Reply With Quote
Old January 22nd, 2004, 07:05 AM   #2 (permalink)
Tom P.'s Avatar
The glue may just fuse it in place without getting to the problem spot.
When I shellaced my Pro Jr I stripped the cab. I took the metal plate off by removing the back panel and pushing the tips of the brads back out. I used needlenose pliers to pull them out and remove the plate. Its slow work as you don't want to scratch or bend the plate.
Try taking off the plate and putting some masking or duct tape on the back of the plate to "deaden" the vibration. Hope this helps.
Just Pickin'
Tom P. is offline   Reply With Quote
