blackface Deluxe Reverb Replacement Speaker
Many opinions: what replacement speaker gets closest to the original Jensen or Oxford? Not looking to expand on the vintage sound, just find a speaker to recreate the original tone as much as a new speaker can replace the tone of a 40-year old speaker.
If you really want that same type of speaker (instead of something more robust) try the low end of the Weber line, like the Signature 12s. At $35 you just can't go wrong.
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
+1 on Weber, but for an amp as nice as that, a little higher end speaker than the Sig series is in order. Try a 12F150.
If you want to go whole hog and get something that will really sing, try a Celestion Gold. |
Both Weber and Celestion Gold were my first inclinations, but I was wondering whether the Celestion would be a little too Brit sounding to be authentic? I have no experience with the speaker, so this is probably an unfounded concern.
My '66 has a ceramic Oxford. It's not a particularly good speaker that I would care to replicate. I put a Warehouse Speaker "Veteran 30" in my '69 DR and it's the best sound you can imagine coming from a DR. It is substantially better sounding than my '66, due to the speaker change. ( And the '66 sounds very good)
I'm Makin Progress |
I went with a Weber Alnico Blue Dog since I couldn't afford a Celestion Gold. I wouldn't say it sounds British, just sounds like a good alnico loudspeaker. Mine's in a '77 SFDR though if that matters all that much.
#11 (permalink) | |
#15 (permalink) | |
#16 (permalink) |
I may be mistaken, but from what I've read here and other places, it seems that almost nobody still has the original speaker in their blackface Fenders. Either because the original blew, or because of the sonic limitations of the original speakers.
#17 (permalink) | |
Any number of replacement speakers will sound better and provide more robust performance than the originals, for certain. I am currently using an Eminence "Fender red/gold label" reissue (50W) in my BFDR, it sounds really fine. Prior to that I used a JBL E-120 for years, incredibly powerful. Both of those speakers smoke the original Oxford by leaps and bounds.
#18 (permalink) | |
#19 (permalink) |
I can tell you from experience that a DrRreally responds to a speaker upgrade. Their stock speakers basically were not that great. Put in something with some beef and the DR sounds way bigger. I ended up putting an old reconed jensen P12N in mine. Sounds great. The Weber 12A150 would be my second choice.
#24 (permalink) |
Eric Johnson's using JBLs in both of his DRs; however, he's dialed them for his clean tone. That said, for a cleaner-louder tone, go with the Weber Calif12 w/paper. For my fav, the Weber Blue Dog - Ceramic for more headroom; Alnico for more touch response. Beautiful!
Vaya con Dios, JonesKY 6-string Double Baritone Ukelele |
#25 (permalink) |
Just a note: having used JBLs for years, I can say with confidence that they increase the perceived loudness of the amp by leaps and bounds. If you want to use a DR at lower club volumes and still want it to break up, the JBL will seem like overkill. On the other hand, if you want loads of clean, clear headroom then the JBL is untouchable.
I recently replaced the JBL E-120 in my '65 BFDR with an Eminence (Fender Gold reissue) speaker because I no longer needed or wanted all that headroom for the gigs I am doing these days. Here's a comparison at the same gig with the same players and the same stage level: JBL: amp volume control never goes past 4.5, amp is barely breaking up with the guitar/volume pedal is floored. Very clean. Eminence: amp volume control at 7.5, amp is levitating and floating around the stage area. I will never get rid of the JBL - it's really great. When I once more need a really clean amp, I'll just put it back in. But for now I am really enjoying the super "traditional" sound of the Eminence. I should note that I am really impressed by Webers, but this Eminence was free in a swap deal. Can't beat that.
#26 (permalink) |
If you could find one, a Reverend Alltone 12" is a great speaker. I've read that a Weber Sig 12B is a similar speaker to that one. I've been running my Champ II (18w, 2 6V6's) for the last couple months with a Rev in a separate 1x12, and it sounds incredibly sweet, especially recorded. In the combo itself I installed a 10" brown frame alnico CTS that sounds good too, but the bass tends to fart out when cranked up.
#27 (permalink) |
I replaced my Weber 12F150 (excellent speaker tho) with a Celestion Gold (HOLY CRAP! what a sweet speaker!) and couldn't be happier. But I know a lot of guys who like the 12F150, Tone Tubby, Emis and all sorts of things in their DR's. I'll also second that very few of my friends who own old DR's and actually play them still have the original speaker installed. Almost all have the original in a box in their closet or something.
#28 (permalink) | |
TIA- |
#31 (permalink) |
Anyone in Australia should give the Melbourne made Lorantz 30 watt Greenback clone a try.I pulled a JBL K120 out of my DRRI and put it in an extension cab so that I could get better breakup from the Lorantz in the amp.It sounds great.The JBL is a superb articulate speaker that gets VERY loud without breakup. Lorantz are made at the old Rola Plessey plant and I am led to believe custom speakers are very possible .
#32 (permalink) | |
Thanks
"I like the British bikes. I like British people. They're real mellow."-Mike Tyson "You must surrender whatever preconceptions you have about music if you're really interested in it."-Cecil Taylor |
#33 (permalink) |
BTW The weber 12f150 is an amazing speaker, its going in my Princeton once I get a 1x12 baffle for it.
#35 (permalink) | |
I did not notice much loss of headroom or SPL with the Gold vs. the 12F150. The Gold is a pretty darn efficient speaker (Sensitivity rated at 100db@1w@1m). They both broke up at about the same number on my volume knob and seemed just about as loud. The Gold however, breaks up a bit creamier I guess and has a bit more compression due to the Alnico magnet. Both outstanding choices though! I will add that of the Weber 12F150's, I prefer the 12F150T. |
#37 (permalink) |
I still have the original Oxford speaker in my early 65 DR and the amp is the most ridiculously wonderful sounding amp I've ever plugged into. The speaker code says it was made in Aug. of 1964.
#39 (permalink) |
I have this exact speaker sitting in my BFDR. Sounds sweet and vintage.
myspace.com/thomasfarnan |
#40 (permalink) |
Red Fang
I have a Red Fang in deluxe reverb and love it. Here you can listen to some sound samples all played with deluxe reverb with red fang and stratocaster. http://www.myspace.com/earlandtheslimline
I also use weber beam blocker and it is great too. Earl |
