Old August 22nd, 2008, 06:44 PM   #1 (permalink)
Sidney Vicious's Avatar
What gauge wire speaker to chassis on Fenders?
What is the gauge of the wire that came stock on vintage Fender amps from the speaker to the rca plug? The black and white twisted stuff?
thanks.
Sidney Vicious is offline   Reply With Quote
Old August 23rd, 2008, 09:40 AM   #2 (permalink)
Nobody?
Old August 23rd, 2008, 12:08 PM   #3 (permalink)
DavidP's Avatar
18 ga stranded...
that's what I have in my SF Fender amps.
barely in tune and teetering on the brink of oblivion...
DavidP is offline   Reply With Quote
Old August 23rd, 2008, 03:22 PM   #4 (permalink)
I was afraid of that - 18 like lamp cord?
The solid stuff I was going to use is 22 gauge - is that dangerous? Will it work as well?
Old August 23rd, 2008, 05:10 PM   #5 (permalink)
Darcy Hoover's Avatar
18 gauge is the stuff you need.
http://www.mojomusicalsupply.com/products.asp?id=566291
Darcy Hoover is offline   Reply With Quote
Old August 23rd, 2008, 09:13 PM   #6 (permalink)
Don't use solid at all. It's just going to fatigue and break. And 22 gauge is too small.
Get some zip cord from a broken hair dryer or pick up a cheap (not too cheap) extension cord at the dollar store.
Or if you want the black wire/white wire look, buy three feet of 18/2 SJ wire at Home Depot or Lowes and strip off the insulation. You'll find good-quality 18 gauge stranded wire inside.
Billm is offline   Reply With Quote
Old August 23rd, 2008, 10:05 PM   #7 (permalink)
That sounds like a plan!
Thanks gents.
Old August 25th, 2008, 06:22 PM   #8 (permalink)
22 gauge is fine..like many things in the guitar amp world there are many myths that continue to prevail ... this is from a McIntosh Engineer (McIntosh makes sone of the finest engineered amplifiers in the world - and yes, folks (Grateful Dead in particular) use them for guitar and PA amps. Here is an what McIntosh recommends:
Maximum Wire Lengths For TWO CONDUCTOR Copper Wire
Wire Size 2 ohm load 4 ohm load 6 ohm load 8 ohm load
22 AWG 3 feet max 6 feet max 9 feet max 12 feet max
As you can see, you can use 22gauge wire into an 8 Ohms load for up to 12 feet of length
good old zip cord is fine, and stranded v. solid makes no difference.
cheers !!
20 AWG 5 feet max 10 feet max 15 feet max 20 feet max
18AWG 8 feet max 15 feet max 23 feet max 30 feet max
jeffM is offline   Reply With Quote
Old August 25th, 2008, 07:01 PM   #9 (permalink)
It's not about the current capacity.
Why would anyone put solid-core wire into an application where it terminates at a plug and lives inside an area where it's subject to movement from people stuffing the line cord into the amp, putting pedals in there, etc.?
Stranded is for ruggedness/resistance to breakage and 18 gauge will certainly stand up better than 22 gauge if it gets some inadvertent tugs, pushes and pulls over the years.
Old August 25th, 2008, 07:21 PM   #10 (permalink)
bradpdx's Avatar
That's why I'm voting for lamp cord. Cheap and to the point.
String bender ordinare!
Old August 25th, 2008, 11:09 PM   #11 (permalink)
Ordinary white and black lamp wire, oldest hardware store in town.
pbenn is offline   Reply With Quote
Old August 25th, 2008, 11:55 PM   #12 (permalink)
Fatter wire will sound a little better, I like 12 gauge stranded when I can find it.
Old August 26th, 2008, 12:36 AM   #13 (permalink)
Uh-oh, time for a blind A-B comparison!
Old August 26th, 2008, 01:00 AM   #14 (permalink)
I'm convinced on the stranded - and 18 is readily available - but just for authenticity -
is 18 stock on the old stuff in that application?
Old August 26th, 2008, 07:55 AM   #15 (permalink)
Yes, 18 gauge was stock.
Old August 26th, 2008, 09:03 AM   #16 (permalink)
Thanks, Billm.
Old August 27th, 2008, 05:22 PM   #17 (permalink)
not trying to flame you Bill M but it is about current capacity.. the OPT transfers high voltage low current into low voltage High current and that goes thru the speaker wire. So the gauge is chosen based on the length required as shown in the chart I provided from McIntosh. Yes 18 gauge will hold up better and stranded is less prone to breakage if moved around a lot.
cheers!
Old August 27th, 2008, 06:54 PM   #18 (permalink)
Heh. And this twine has a breaking point that's a full five lb. over my weight. But I think I'll find something with a little more headroom before I go mountain climbing.
