BF Champ Extension Speaker - Telecaster Guitar Forum
Old July 16th, 2008, 02:47 AM   #1 (permalink)
Just picked up a '66 Champ in exc. condition. I would like to use the speaker as little as possible to keep it in said condition.
Looking at Ampwares site, I see they have RCA plugs and wire. I am thinking I could get another speaker and wire it up to the plug and, voila! Extension speaker for the Champ.
Also, I am guessing it would be possible to put the RCA on one end and a 1/4" on the other to use in a cabinet.
Any thoughts? What gauge wire would be best?
Thanks in advance.
Johnny Halo is offline   Reply With Quote
Old July 16th, 2008, 03:23 AM   #2 (permalink)
eugenedunn's Avatar
Are you against pulling out the RCA jack and replacing it with a standard 1/4-inch jack? It is a direct drop-in, with no drilling needed. Very easy to do.
If, on the other hand you don't want to mess with it, I suggest you put your Champ in a head cabinet and wire a RCA plug into the back panel jack. Then your original cabinet and speaker will remain unused.
EHX Hum Debugger > Barber TonePress > Fulltone MDV-3 > Bixonic Expandora > Q-modded BudWah > XP300 Space Station > > Keeley Neutrino Envelope > Keeley AD9 > Express XT Looper > Peterson StroboStomp > ISP Decimator > Fulltone TruePath ABY > The Amps....
eugenedunn is offline   Reply With Quote
Old July 16th, 2008, 10:14 AM   #3 (permalink)
I was thinking that making a wire(s) would be the easiest and least invasive way to go.
Sponsored Links   #
Old July 16th, 2008, 10:34 AM   #4 (permalink)
eugenedunn's Avatar
This is a pretty straightforward plug n play setup. I would recommend it if you're gonna transport your amp and plug into cabinets all the time.
Have you thought about removing the existing speaker and storing it? Just replace with a robust Weber 8F125 like I did. Much louder, and late breakup. 3.2 ohm vintage correct impedance, 30-watt rating.
Old July 16th, 2008, 11:31 AM   #5 (permalink)
Or you can get a RCA-to-1/4" adapter and use a regular 1/4" speaker cable to an extension cab. I believe Weber can make any speakers with the stock Champ speaker impedance.
WrapAround is offline   Reply With Quote
Old July 16th, 2008, 11:53 AM   #6 (permalink)
eugenedunn's Avatar
I think WrapAround's got the easiest solution, but the RCA jack is inherently kinda weak.
Like I said earlier, if you plan on connecting and disconnecting a lot and transporting a lot, you would do well to either go for the beefier 1/4-inch jack or even the head cabinet route.
Old July 16th, 2008, 12:10 PM   #7 (permalink)
SamBooka's Avatar
I have done the 1/4 to RCA adapter thing in the past.
2 issues.. Very long and weak. Also more weight straigh down on the RCA jack and with vibration the RCA plug can fall out.
I made a custom cable using lamp cord (I know.. but it seems to work for me) since I didnt want to replace the RCA jack with a 1/4". I loop the cable through the handle so the weight is not being held by the RCA jack.
Cheers
Drew
SamBooka is offline   Reply With Quote
» Random Photo for Guests
Gibson SG Elite 1990
» Recent ThreadsGuests
Fender Logan Custom Guitars
