Help Narrow Down Fender Amp Choices!
I have narrowed my amp search down to a Fendar tube Amp. The Twin is just too loud to use in my home ( I do not play live ). I have a budget of $ 1,000.00 for just the amp. I play ( or attempt some days ) a ton of different music ( Stones to AC/DC to Dick Dale). The only guitars I will be running thru this amp will be Teles and a G & L Legacy. I guess I need a jack of all trades amp. A single speaker is fine as long as it can get decently loud without breaking up. The catch is I want to buy this amp tomorrow ( then I have 3 days to noodle for the 4th ) ( instant gratification is American ). Guitar Center has all the main line Fenders in stock. I played thru the DRRI & Hot Rod Deluxe yesterday with a Tele and both sounded pretty good ( I only had time to try out the two ). Are there any other Fenders I should try before buying? Please help me spend my money and fuel the economy!
OF the two you mentioned for themusic you play, I would have to have the DRRI for the Dick Dale thing. The HRD doesn't have tube reverb...which is a must have for surf, imo. You would have to go to pedals for the overdrive sounds. T he new Prineton Reverb RI might suit you at lower power.
From the sound clips and demos' I have heard...The New Princeton is the way to go.Check out a SuperSonic if one is there....I really liked the one I played through with humbuckers and singles.
I like the DRRI a lot -- but $950 is overpriced. It was a good deal when it was $800 a couple years ago. You can find them for $600 used.
Check out the Custom Vibrolux Reverb. More of a rock/blues amp because it breaks up very early. The 10s are nice and punchy. Some have complained about a hiss with this amp, so pay attention for that if you test-drive it. |
#10 (permalink) | |
Take you time, play each one and see which best suits your musical style and tonal requirements. Nobody has mentioned the SCXD, but I have one, and BillM has two of them! I love mine. It's a great little notemaker with plenty of versatility. For more $$$, I would suggest the DRRI or the Princeton Recording, then the BJr or the PJr (stay away from the other Hot Rod Series amps). Good luck! |
Well I pulled the trigger and bought the DRRI. I played the Princeton Reverb and then the DRRI on a 52' reissue Tele for about 30 minutes each. I was torn between the two. ?They were both great amps. I think I chose the DRRI because it gives me the means to play with others if I ever get good enough and it has been out for a while and seems to be well regarded by most folks who have it. One thing is for sure, I will never go back to playing a solid state amp again. Even for my novice ears, the difference in sound is night and day.Thanks for all the input, it really helped!
I think you made the right decision.
The DRRI is probably the more versatile of the 2 amps as it's plenty loud enough to use in a band situation and still gives great tone at lower volumes at home. The PRRI would struggle to keep up with a band in my opinion.
Someone told me that my tone is in my underpants. I'm not sure if that's good or bad...... |
