Old June 30th, 2008, 12:10 PM   #1 (permalink)
Parts from PC or TV?
I had to recycle an old computer yesterday so before bringing it to the yard, decided to tear it apart. The big monitor had a tube in it, but it seemed to be one-piece with the glass screen.
Anyway, is it worth it to take any other parts (caps, Trannies, etc) off of these or are they generally too much work to de-solder from the boards?
I'm thinking it's the latter, even though it was interesting to poke around in there.
Little Ricky is offline   Reply With Quote
Old June 30th, 2008, 12:31 PM   #2 (permalink)
Most of the caps are not amp-friendly values. Sometimes it can be a pain to desolder from the PCB boards.
If you're broke, go for it. Use the color bands to find resistors of values you need. You'll likely still need to buy more parts, but at least you can shave of some costs by scavenging.
Old June 30th, 2008, 01:26 PM   #3 (permalink)
IronJoe's Avatar
I once found a webpage where a guy had re-shaped an old computer case into an amp chassis. Looked around but couldn't find it for you. Might save you a few bucks if you're looking to build.
IronJoe is offline   Reply With Quote
Old June 30th, 2008, 01:53 PM   #4 (permalink)
Scott S's Avatar
Never hurts to scavenge parts from electronics you're going to throw out anyway -- fans, thick wires from the power supply, resistors, mini-chokes, ceramic caps, etc. Not that you could build a whole amp from them, but...
- Scott
Old June 30th, 2008, 02:08 PM   #5 (permalink)
Too much work
- Scott
Yeah, I ended up just keeping 2 fans and the easier-to-remove thick wires, and a bunch of screws. I actually thought of using the chassis as a cab, ala GK micro series cabinets, but overall, I'd say it isn't worth taking these things apart. Just wanted to see if others had had better luck.
vB code is On
Forums Directory
