If you're talking about an amp with two inputs per channel, yes it is. This is because the 2nd input has less input resistance than the 1st channel, which has a 1 meg resistor to ground. It is intended for high-output pickups like hummers, to help get a good clean tone out of them - remember, this is how Leo and Co. were thinking back then, clean not overdrive.
On lower output pickups like single coils the buffer of the higher input impedance helps the pickup to generate a stronger signal. Today you'd probably use it for active or very low-impedance pickups.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
#4 (permalink) | |
Yes, It's normal
+1 All the old fenders work like this. I always put Humbuckers in #2 and fenders in #1 |
It doesn't really work that way. Although you're decreasing the gain of the input slightly, like turning down the volume on your guitar, it doesn't effect the output produced by the power tubes. So, the effect would be a cleaner tone but at the same output volume. You'll still be loud...just cleaner. I suppose by turning up the volume you'll drive the power tubes harder, but it's not like having a master volume or clean boost.
As others have mentioned, you use the second input to tame hot PUs which might be overdriving your preamp too early or to thin out the input tone. I know some soul/R&B guys that use them with their Strats to enhance a thin procrussive rhythm...then they step on a clean boost for leads. |
#9 (permalink) | |
Not really, power scaling or an atenuator will do that for you. |
Moderator
Yup, that's what I've always done also. Plus, if you have a single coil guitar with very bright pickups (Texas Specials, eg.), it tones those down by using input #2 also, takes some of the bite out of them.
