Old June 28th, 2008, 01:46 PM   #1 (permalink)
appar111's Avatar
4 ohm speaker ok in a 5F2A Princeton?
All the Princeton kits I've seen come w/ an 8 ohm speaker, like mine. Can a 4 ohm speaker be used w/ this type of amp without any ill effects? Will there be any difference in sound from an 8 ohm version of the same speaker type?
appar111 is offline   Reply With Quote
Old June 28th, 2008, 02:02 PM   #2 (permalink)
Which OT is yours using?
Many kit makers use multi-tapped OT's. If so, you can use the 4 ohm tap and just wire it to another output jack.
Old June 28th, 2008, 04:08 PM   #3 (permalink)
appar111's Avatar
only one speaker out, don't want to do any wiring, etc. just want to know if a 4 ohm would work in my amp which is set up for an 8 ohm speaker.
Old June 28th, 2008, 04:26 PM   #4 (permalink)
It should be safe, it just won't be optimal.
teleamp is offline   Reply With Quote
Old June 29th, 2008, 08:20 AM   #5 (permalink)
59TweedVibrolux's Avatar
As was mentioned, it will be safe but won't sound great. The amp you have
will have an O/T for an 8ohm load. The Original Tweed Princetons were
4 ohm. Modern Clones should have a Multi Tap O/T 4ohm / 8 ohm as was
also mentioned.
So you can use a 4 ohm speaker, but it won't sound as dynamic or good.
This is a 4ohm Triad O/T from a Tweed Princeton
59TweedVibrolux is offline   Reply With Quote
Old June 29th, 2008, 04:37 PM   #6 (permalink)
appar111's Avatar
So the P/T on my modern version of the 5F2A would have a multi tap, but not necessarily have two separate ohm jacks (4 and 8)? I figure if there's any soldering/wiring around the P/T, then I'd be better off just tracking down an 8 ohm speaker.
thanks, guys!
Old June 29th, 2008, 05:00 PM   #7 (permalink)
Scott S's Avatar
OT, not PT...
Old June 30th, 2008, 10:06 AM   #8 (permalink)
bradpdx's Avatar
If your new kit specifies 8 ohms, best to stick with that. You could check with the manufacturer to see if they will substitute a 4 ohm OT, but I agree that 8 ohms is a better and more universal choice for a single speaker amp.
String bender ordinare!
vB code is On
Forums Directory
