Old June 27th, 2008, 08:32 PM   #1 (permalink)
replacing 1965 TRRI pre-amp tubes
Hey guys,
I’m looking to overhaul my ’65 twin reverb pre-amp tubes. Since I am only using the second channel, would this set of pre-amp tubes work well? 2 JAN GE 5751s for V2 and V4 (will this tube work here?). and a Mullard CV4024/ECC81/12AT7 in V3. the stock tubes will remain in V6, V5, and V1. I have never swapped out my tubes. All I have to do is unplug the amp, pull out one tube, and put the new one in right?
Thanks for any feedback.
darkstar73 is offline   Reply With Quote
Old June 27th, 2008, 09:20 PM   #2 (permalink)
Put the best tubes in the first position for the channel you use the most V1 for the "normal" channel and V2 for the "vibrato" channel. That will make the most noticable audible difference.
teleamp is offline   Reply With Quote
Old June 27th, 2008, 10:40 PM   #3 (permalink)
JimiBryant's Avatar
preamp tubes (the little ones) can be swapped with no problem.
you might try varying the order to see if any particular set-up
sounds better than another.. a 5751 is basically the same as a
12AX7 although it's less gain, for lack of knowing the proper term.
those GEs are nice! the Mullard CV4024 you have may or may not
be what you want in place of a 12AX7 but of course if your V3
is already a 12AT7 then no worries.
anyhoo: with preamp tubes and I believe rectifiers as well there's
no need to re-bias or anything like that.
careful! let 'em cool off before touching 'em because those little
buggers get HOT!!
I'm sick and tired of following my dreams,
so I'm just gonna ask 'em where they're
going and hook up with them later!
JimiBryant is offline   Reply With Quote
Old June 28th, 2008, 08:06 AM   #4 (permalink)
You might want to contact Mike at KCA tubes in Springfield, Va.
Not only does he sell LOTS of NOS tubes.....but he also works on LOTS of Fender amps.
He's a real good guy to deal with and about as knowledgeable a Fender tech as you will find.
Good luck!
Steve
6942 is offline   Reply With Quote
Old June 28th, 2008, 07:53 PM   #5 (permalink)
looks like i'll contact mike and see what he thinks. thanks for the suggestions.
Old June 29th, 2008, 12:26 AM   #6 (permalink)
Scott S's Avatar
I'd suggest that at this point, the only tubes that *might* need replacing are the power tubes.
Scott S is online now   Reply With Quote
Old June 29th, 2008, 11:48 AM   #7 (permalink)
JKjr's Avatar
KCA
+1 6942. I love the old GE's in my twins. Many prefer the RCA's, and I believe they were OE in the day. Either way, Mike is the man. Think about what it is specifically that you would like to alter in your amp; ie brightness, drive, clean headroom etc... or just ask which he prefers. Either way you win.
JKjr is offline   Reply With Quote
Old June 29th, 2008, 09:02 PM   #8 (permalink)
i got the amp last November so the power tubes are fine. they are the white GTs that came stock in it. i was thinking pre-amp tubes because i heard this was one of the quick and easiest ways to change the tone of the amp. i am basically looking to take some harshness out of the highs and earlier breakup.
Old June 29th, 2008, 09:10 PM   #9 (permalink)
woodman's Avatar
i wouldn't think 5751's for earlier breakup ... seems like they would give you more clean headroom. of course, it all depends on the amp, your style, etc.
BAND PAGES:
Old June 29th, 2008, 10:44 PM   #10 (permalink)
Scott S's Avatar
Hate to say it, but if you're looking for *any* breakup, you probably have the wrong amp there. Your eardrums will overdrive before the Twin does!
- Scott
Old June 30th, 2008, 09:29 AM   #11 (permalink)
Well, there's that...if 'overdrive' is what you're after, you're gonna need to do a lot more than change your tubes with that particular amp.
Yes, 12A?7 tubes are all interchangable with no risk of damage to your amp, though 12AT7s and 12AU7s are designed to do a different job than 12AX7, 12AY7, 5751 & 7025s. A lot of these tubes have different names, as well, depending upon for whom they were sourced/packaged. But it's really all a matter of taste, so have at it.
JimiBryant is half-right--rectifiers do not require any sort of 're-bais' to change, BUUUT they can damage your amp if swapped out indiscrimantly. There are several common guitar amp rectifiers, each a bit 'more powerful' than the last, and switching a lower-scale recto (say, a 5Y3) for a higher-scale recto, like maybe a GZ34, will throw off most of the voltages throughout the amp, possibly damaging a lot of expensive little bits inside--unless you're a real knowlegable guy about that stuff, I wouldn't switch recto tube models. Switching around brands is usually not a problem.
marshman is offline   Reply With Quote
Old June 30th, 2008, 11:30 AM   #12 (permalink)
Scott S's Avatar
Luckily for the OP, there is no rectifier tube to worry about.
- Scott
vB code is On
Forums Directory
