Homemade Cables sound dull
I purchased 50 feet of Canare GS6 Cable and Some neutrik ends. I soldered them together and they work well but I have come to find that My Cheap GC cables are much brighter and clearer. A member in another thread, suggested that I might have the black conductive sleeve making contact with the center wire, This was not the case. I checked all of my newly made cables and they are all muddier sounding cables than the CG House brand cables.
Any thoughts here?
" Trust me, I saw this in a cartoon and I'm pretty sure I can do it! " http://www.myspace.com/bmwsteve Guitar Photos |
| Sponsored Links |
I use the same Canare/Neutrik cable combination as you do in a 15 foot length.
I think it sounds much better than the Planet Waves cable it replaced? But then....my poor ears a lot older than yours. How long are your cable lengths? I like using Kester 63/37 245 solder....but I'm sure others have their own favs. Steve |
#4 (permalink) | ||
Could it be the solder? This is supposed to be low capacitance cable, I thought I'd end up with clearer sounding cables.
Is the new cable really "muddier" or is it just not as bright?
The new cable might not have as much tizz factor, which some may view as a plus. It might be richer in the mids, more subdued in the treble. Possibly a more 3-D kinda sound. In any case, this is what I would expect in moving to a higher quality wire. I have not tried the cable in question though... Whether you like it or not in your rig is the ultimate thing. |
#6 (permalink) | |
If this is what the cables I made are supposed to sound like, I wasted my time and money. I could have gotten several CG cables for the 60 bucks I spent on dull sounding piece of hose. It's like a big capacitor is being used
I wonder if Bill And Becky's cable kit subdues the treble as well or if they are bright and clear. I think I'll cut the ends off and toss them in a parts box and Maybe I can use the Canare Cable to bundle up some tree limbs for trash pickup.
This can happen if there is a resistive load between
the cable shield, the place you solder the cable to under the shield, and the sleeve on the jack. I had this happen with a cheap jack that was press fitted together. If you wiggled it with an ohm meter attached it could go as high as 5 ohms.... decreased output and diminished brightness was the result. Also one fiber of shield wire touching hot tip path can do this.....meter out the cable....if it passes then its a capacitance issue |
#9 (permalink) | |
I dont have any of the conductive sheild touching the center and I'm confident that the ground webbing isn't touching either. Can you explain how/what you mean by "Meter out the cable"?
#10 (permalink) | |
Stew Telefuntastic! "It's downright laziness to get up, when you have the will to lay in bed" - My Dad, 1906-1978. http://www.myspace.com/award_session |
I have to say that all this cable hoopla adds up to one thing. They sound different. But different doesn't always mean better.
To an engineer, a tube amp is an abomination of inefficiency inducing distortion into what should be a totaly clean signal and they'll prefer a solid state amp every time. But then a player plugs into a tube amp and it's smiles all around! On paper these "super" cables might appear better but that doesn't necessarily mean they sound better. Different? maybe. Better? Just don't ask a guitar player! Too many different answers!
Dogs have the right idea! |
Well, Rotelli, thanks for sharing the story!
Clearly, different cables sound different. I used to make my own with Belden 8410 cable, and they opened up the treble like nobody's business. Going back to the cheaper storebought cables of the day was like putting cotton in my ears. I've heard that George L cable is supposed to be bright-sounding; haven't tried it.
"It looked like a giant green gum drop to me." |
It's not a resistance problem and it's certainly not the solder!
As I recall, Canare cable has a fairly high capacitance per foot, around 50pF. (I'll look this up later if I get a chance.) So even a 10 foot cable is adding 500pF to ground. It acts as a low-pass filter. On paper, it's a first-order low-pass filter, and it rolls off highs at 6dB per octave. The actual amount may be greater after it's done interacting with your guitar and amp. GS6 cable is built for low microphonics, not low capacitance. It resists handling noise, slapping against the stage, etc. I use Mogami cable for the same reason, but it has almost half the capacitance of the Canare. The amount of roll-off you get from a cable is dependent on both your guitar and your amp--they form a resonant circuit. That's why some people report great results and you try the same cable and hate it. BTW, the brightest cable in my collection is some cheap Chinese 20 foot POS that a used-guitar dealer gave me when I bought a bass for my son. The plugs were crap; I replaced them with Neutriks. It tends to break at the strain reliefs, so it keeps getting shorter in 6-inch increments. But it sounds great. Go figure. |
#14 (permalink) | |
Let it be said... cable can only attenuate the HF running along it. The cable cannot alter the harmonic structure of the sound. So it is exclusively capacitance that is the culprit. At high impedances of the order experienced with guitar amps, a few ohms of resistance is not going to make the slightest difference to the signal in any way. There could be a small amount of inductance in the cable, but that will be inaudible compared with the huge inductance of the PU to which it is connected. We just need to apply the KISS factor here. It ain't rocket science!! If your guitar sounds great to you, and you continue to get paid to play... then that's all you need to worry about. I hear many people with great sounds these days. I hear guys with loadza dosh that have 'bought' a sound EXACTLY like Hank Marvin... but can't play like him, some have 'bought' the EXACT Roy Bucannan sound... but can't play like him... do I need to go on? Spend your time worrying about your playing ability AND developing a unique style of your own. No one will ever reach the pinnacle of earning ability by copying someone else! It's already been done!! Having the very best gear alone, will NOT make anyone a GREAT player. I'll leave you with this thought. Max Factor said... "We don't sell makeup... we sell hope!" Good luck!
#15 (permalink) | |
if the cable tests OK with a meter... |
#16 (permalink) | |
Here is what I read and believed
I missed the Technical spec's that state the capacitance @ 49.0 pF/ft. Not that I would have known what that meant. I excepted the claim of,"Low capacitance and low series resistance provides improved frequency response (flat to 50kHz). A bright, ringing characteristic sound is preserved...". Is 49.0 pF/ft considered Low capacitance? Live and learn
#17 (permalink) | |
Thinking about this some more, I wonder if you're getting mids peaking, not highs roll-off. If the highs are still there but the mids are being emphasized (resonant circuit with your pickups), that could sound like diminished highs. |
#18 (permalink) |
Bill,
No matter which of my guitars I use with Pickups from Keystones to Toneriders, humbuckers to P90's they all loose some treble, like I'm rolling back the tone knob a bit. When I change to the adjustable Bias a few weeks ago and emailed you that It sounded duller, you thought I might have had the bias set a little hot. It turned out to be my new Canare cable, although I did roll the bias back from 4.7 to 4.2 and it sweetened things up a bit for any cable I might use. What cable are you using that is 25-30pF per foot? The best I saw from Mogami in guitar cable was 39.7pF per foot (W2524 cable). Bill Lawrence sells cable that he state is 20pF per foot. I know it's extra skinny cable so I wonder how well it handles microphonic, handling noise. Like most of his stuff, it looks different then the rest of the worlds guitar gear, But it always seems to be the best sounding stuff! Looks like the GC cables are the way to go. I had the end come apart on one a few weeks ago and they replaced it without a problem. But I can't stand the way the barrel on the connectors unscrew so easily, I have to solder them shut and the grind it off before I go to GC so that they can inspect the break.
#19 (permalink) |
I went to GC and picked up 5 ft of the Planet Waves bulk cable. At $1.50 it's not a bargain to by a bunch of it at the store. I went to Radio Shack and pick up a couple of run of the mill 1/4" connectors. I came home, solder it together and test it against the other two cables.
The Planet Waves cable is by far the clearest and brightest cable of the bunch. I can't find any specs for this cable to give me a reference point from the Canare cable. I wonder how the Mogami W2524 would compare. Be for I did the test I carefully went through and checked the Homemade cable it metered out fine but I cut and re-soldered one end that looked questionable, the cable still sounds thick/dull. If you can remember what that 25-30pF cable is Bill, I'd sure like to know.
#20 (permalink) |
Mogami 2524 sounds pretty similar to GS-6. I've heard that George L cable also sounds pretty similar, though I haven't tried any of those.
The GS-6 definitely has a smoother, more emphasized mid-range, but I wouldn't call the ones I have 'dark' by any stretch. I would assume it depends on some level what combo of guitar, cable and amp you're using.
![]() Wicket KNOWS. |
