40's Epi Electar build
Hey guys, I'm working on amp #2 and I decided to do a 40's Epiphone Electar. I've got the board done (hopefully correctly) with many thanks to Johnny Crash. So here are some pics. I'm currently getting the chassis drilled and all that stuff I may run into some trouble there because my chassis is going to be tight but we'll see.
"Don't just play something, stand there." |
| Sponsored Links |
All Epi's looked like this back in the day.
I meant getting the schematic translated correctly into a working layout. I have the holes for the sockets done, next I'll probably drill all my other holes. Man is it going to be a tight fit!Jason
A '40s was likely point to point (and a pain to service). I think dangelico603 just means he hopes the schematic is "right" with the layout he's drawn/drilled/staked for it.
From the schems you sent me, this will be an interesting amp. Very primitive 6L6 circuit... it should sound great for the music you described. This will be a fun build to watch!!! |
Hey guys, how do you all typically mount your tube sockets. I'm wondering how to mount them so as to have my heaters away from signal wires etc. I've seen Weber's layouts for some stuff and he seems to put the heaters' lugs facing the back corner but it seems to me you would want them where the heater wires wouldn't have to go around the socket, no?
Jason
Well, here's the almost finished product. I will probably get to fire it up tonight, hopefully without having to use the fire extinguisher.
Double check everything before firing it up.
As you mentioned before, I made some mistakes and overlooked some stuff on the first layout you sent me. It is a sparse and simple circuit, but you should still double check it :) Very neat wiring! I can't wait to hear how it goes and how it sounds!!!! |
All right I checked everything twice then fired it up.........no smoke which is good......sound, which is a positive but it sounds quiet and far away and almost out of phase or something. Any thoughts?
What is up with your 3rd filter cap? Is that grounded? There doesn't seem to be any dropping resistors between filter caps either.
How about your 6L6's cathode resistor, is that grounded too? Double check your actual resistor values. Your input grids, plate resistors, and cathode resistors. |
#11 (permalink) | |
