couple of amp questions...
i gig with 2 amps...and an aby switcher...i have a vibrosonic...that when i turn it up over 4 or so it will blurr a little...thats pretty loud...but it shouldnt blur should ity??is this tubes??? bad..or just overdriven?
my dirty amp is a marshall jcm 2000 triple super lead combo amp 60 watts.. and when i turn it up to a good playing level..when its on the dirty channels it wants to sit and feedback even when the aby box is going into the fender.... i have adjusted the highs and lows...but it seems the only weay it will stop squeeling is to turn it down how can i solve these problems? |
| Sponsored Links |
Vibrasonic....what are your tone control levels when you go over 4 on the volume?
Marshall.....you probably have a micorphonic tube that is going into a feedback mode...tap on your tubes o ne at a time to see if you get a high-pitched, loose-sounding reaction. That would be your problem tube. |
vibrosonic is set at 8 for higs 4 for mid and 5 for low
and the marshall is brand spankin new...i guess that still a tube could be microphonic right? on edit: the marshall will get quiet if i switch to the clean channel and of the dirty channels... |
Depending on your guitar and pickups, and any preamps (tubescreamer, distortions, even choruses) over 3 on the bass control on a traditional 6L6 Fender can be too much once volume gets up over mid levels. Part of the reason many of them have a nice early breakup is the power and output transforners are a little short of what they could be. Hot pickups or gain boosters in front make this worse.
Again, your dirty channel on the Marshall is adjustable, and depending on the gain and master volume, you might just be trying to push it too hard. If it does squeal even when not selected, as Wally says, microphonic tube likely. Warranty. Where are you setting the master volume? Usually the master should be flat out or near to, unless you are trying to induce preamp breakup for recording or something.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
so.....are you saying the fender will stop blurring if i turn the bass down on the amp? i have lace sensor pickups in my strat..but there are no chorus or any other pedal between my amp and geetar....i dont use pedals or anything like that.
the marshall will stop squeeling if i turn the volume down low enough....but when i really play loud i have to hit the footswitcher to the clean channel on the marshall to stop the noise. i have some 7025 tubes here...should i swap the preamp tubes out in there and try? |
JEff, on the Vibrasonic, try try lowering the bass control a bit and see if your soncis clear up. those controls are there for a reason. EAch player's approach to playing dictates that each of us learn how to use the guitar and amp control to our individual techniques and taste. There is also the aspect of power tube biasing. If you bias is set to the 'hot' side of things, your distortion will come on earlier. If you can't find a pleasing setting by adjusting the controls, it might be time for a tech to give your amp an inspection jsut to see how the ampl..preamp and power amp sections...are performing. The speaker may not be yielding the soncis you want. there are many possiblities. The controls are the first and easiest approach.
Marshall....I don't have a lot of experience wiht Lace Sensors and high gain, but I have never noticed them giving problems with microphonics. A guitar with microphonic pups will not tolerate high gain situations. However, since in your initial post, you specified that the amp would squeal even when signal was not being sent to and through it, I immmediately suspected the amp. |
i dont run any distortion through my vibrosonic...so ill try lowering the bass..like ya said...
that marshall is less than a year old....so it my need a good ole american 12ax7 in it... thanks guys!!!! |
Not sure whose preamp tubes Marshall is using, but Korg who own Marshall and Vox were using Eis in the Vox, which at one stage had a high microphony/reject rate.
Get yourself a EH or Sovtek 12AX7 (you should have one as a spare anyhow) and sub it in to the various preamp positions - see if it makes a diff. You are using proper shielded guitar cable?
yea...i think i have good guitar cable...but i am going to try swapping around those 2 preamp tubes....i am going to do that this evening
you guys are great help!!! thank you for you info and time!! |
