Old June 7th, 2008, 11:17 PM   #1 (permalink)
Changing tubes on SilverFace DR?
I'm pretty sure my SFDR needs new tubes, it's a little noisy and "loose" and the preamp tubes look original.
I realize it probably needs new caps as well, but I don't want to drop $300 at an amp tech all at once. So can I go ahead and change the tubes myself?
Do I have to do anything with the biasing or will any set of matched 6v6s do?
Do I just pull out the old ones and drop in the new ones?
Also, are the sets sold on ebay OK, like this:
http://cgi.ebay.com/JJ-Tube-Set-for-...QQcmdZViewItem
Or would it be better just to order them from thetubestore.com or something?
Thanks!
Fender 52RI - Gibson SG Standard
'77 Deluxe Reverb
SunFace w/ Sundial - ProCo RAT - Fulltone GT-500
Keeley AD-9 - Boss CH-1
hamish5178 is offline   Reply With Quote
Old June 7th, 2008, 11:59 PM   #2 (permalink)
Scott S's Avatar
If the caps are really old, I'd get those changed first.
Scott S is online now   Reply With Quote
Old June 8th, 2008, 12:27 PM   #3 (permalink)
+1
Cap replacement is your priority. You can test the tubes and see which ones really warrant replacement.
TexGoneNW is offline   Reply With Quote
Old June 9th, 2008, 09:16 AM   #4 (permalink)
Axis29's Avatar
Also, really you may not need preamp tubes. Preamp tubes don't go bad like power tubes.
As stated before, I'd get the caps checked first. If they're good, then go with a pair of power tubes. The problem is, if the caps go bad, those new tubes will be shot and maybe more stuff will have to be replaced on your amp.
John F.
TDPRI # 1764
Axis29 is offline   Reply With Quote
