#122 (permalink) | |
If you can't get it, i'll try to get some pics up tomorrow. |
#123 (permalink) |
I use these instead:
http://www.tube-town.net/ttstore/pro...nd-6-3-mm.html No need for a special tool, and the strain relief is better. steven
"When you have to kill a man it costs nothing to be polite" - WSC |
#125 (permalink) | |
Yep. I squished some index finger skin meat in a pair of pliers trying to get that strain relief grommet in. I also tried a big plastic screw in type (tightened against the cord as it screwed in) a few times. Most of my builds are heads with a socket for a PC type cord, but the ones that weren't were a b!tch to get in. Not easy and definitely not fun... |
#126 (permalink) |
What a great thread! Sure hope Koen & BBB will continue to keep updating their progress. I really, really, want to build one of these, but my knowledge is so limited I just can't go there yet. I'm just beginning to study some basic electronics, though, so maybe eventually. This thread will be an invaluable resource to anyone giving this a try.
The preacher says all my sins is warshed away, including that Piggly Wiggly I knocked over in Yazoo. |
#127 (permalink) | |
Get the strain relief positioned on the cord. ![]() Pre compress it with the cord to eas installation. ![]() Grip from the end and push it in.
#128 (permalink) |
It seems more intimidating than it really is.
I really hope BBB sticks with it. It bums me out when someone gets discouraged and wants to take it to a repair shop... I've been there a few times myself and I hated that feeling. BBB or keon, feel free to PM me for anything. Even if it's just a simple explanation of each part of the amp's circuit. Stick with it! |
#130 (permalink) |
Yeah, I feel the same way, and I've been almost to the point of taking an amp to an experienced tech. My friend wouldn't let me do it: "We gotta get it!"
In my case, I have a hard time figuring out where tenacious ends and cheap begins, or vise-versa...
There is no substitute for Sound Pressure Level |
#131 (permalink) | |
Whenever you feel like that, you can PM me. I learned too much the hard way (read as: "dumb mistakes"), so in that sense, maybe I can help a little better than a "real" amp guy :) HAHAHA |
#132 (permalink) |
I was 99% sure I had lost an OT (I was right.), but wasn't getting readings that made sense. Putting the amp on a 'scope with a signal generator running through it was confusing, too, as it turned out the 'scope probe was inducing some "crap" into the waveform that had us chasing our tails for awhile. Once we (my friend; I can't take any credit for it!) figured out what was happening, it was a no-brainer to see that we had a perfect, clean sine wave entering the OT and a low-level garbage signal coming out of it.
#133 (permalink) |
Getting close to the finishline...
The only thing left is connecting all the wires between the sockets, PT and the board. What's the best way to do this, put the board inplace first, or solder first? Also lugs #6 and 7 from V3 and V4 become really hard to reach for those final connections. Any tips how to do this? |
#134 (permalink) | |
1) Mount the transfomers and sockets, power & standyby switch, fuse assy, and pilot lamp assy. Plus I usually wire the rectifier tube socket, switches an fuse at this time 2) Load board and solder "fly leads" to it. 3) Install board (this is easier with the pots and input jacks not installed) and solder all socket and transformer wiring. 4) Install pots and input jacks and wire up. 5) Run the filament wiring (this depends if I am laying it down or running it in the air, if laying it down, do it before wiring the sockets). As far as lugs 6 & 7, I try to start with the hardest to reach first, take your time. |
#135 (permalink) |
Needlenose pliers help me get wires in place in tight spaces.
I generally put the board in place and then mark the wires. I then pull the board out and trim and strip the leads to length. Excess wires makes it even harder in a cramped chassis. Wire the back side pins first, then the top side ones. Otherwise, you're trying to solder past wires and this can be a pain (plus it could melt wire jackets). |
#136 (permalink) |
BBB, what's the status! I was extra psyched to see a rookie amp build. Hopefully you've found the problem with the help from the experts here. Experience is the best teacher. I'm pullin' for you.
No hurries, No worries. |
#137 (permalink) |
Ok, I'm done!!! - I thought....
All the wiring done, connected the speaker, put in the tubes, turned it on, plugged in the guitar, but no sound All five tubes are glowing, and I can hear some noise (no white noise, but more a 'trrrr' sound) from the speaker, but it doesn't increase when I turn the volume pots. Well, at lest I have no smoke. I will see if I did something wrong with the input jacks or pot wiring. Any suggestions where to start... ? Attached is a picture of the two octal sockets, maybe someone spots an error?
#138 (permalink) | |
And, hey - thanks again guys.... You're all very cool to be so supportive of a grumpy old bastard like me...
BBB. |
#139 (permalink) |
I think I see what I did wrong, the two 100 Ohm resistors on V3 and V4 should be reversed, ie from 2-8 on V4 and 7-8 on V3.
Can anyone confirm that? And BBB - welcome back, man! Take your time, that's what helped me, although not completely as you can read above... |
#140 (permalink) | |
Is this a 5E3? 100 ohm? There are 100K plate resistors... unless you're referring to an artificial 6.3v heater Center Tap. By "V4 and V3" you're meaning the 6V6's, right? V1: 12AY7 V2: 12AX7 V3 and V4: 6V6's V5: 5Y3 Rectifier Please explain. These guys will have to help, I'm leaving for Las Vegas right now... see y'all online Monday! |
#142 (permalink) | |
On the power tube sockets: pin 1 (wire from 2nd filter cap)>470R>pin 4 pin 2 filament, pin 3 OT blue or brown, pin 5>1500R pin 6 (wire from .1 underboard), pin 7 filament, pin 8 cathode |
#144 (permalink) | |
Unfortunately, some solder ended up in the hole of one of the pins, and now I cannot get the tube in position Any idead how I can solve that? |
