Old May 14th, 2008, 05:34 PM   #1 (permalink)
flatpickinfool's Avatar
White noise from a idle 5e3 clone
Just received the the amp today,don't have a guitar to play yet It's a hissy,white noise that comes thru V 3&4. Just past the 2 on the volume and it really stars to get noisy. V 1&2 also have it but at a lower level. I tried loading it down with an old Acoustic guitar stick on pickup and still have noise. This builder is highly respected and so I'm sure the building of the amp was fine. Could it be that this is a normal part of having tubes? If so I'm not sure I can live with the noise. Thanks in advance.
flatpickinfool is offline   Reply With Quote
Old May 14th, 2008, 08:13 PM   #2 (permalink)
DrewB's Avatar
This is a brand-new amp? I wonder if it wouldn't benefit from some shielded wire to the grids of the preamp tubes. My other guess would be a flaky electrolytic...
There is no substitute for Sound Pressure Level
DrewB is offline   Reply With Quote
Old May 14th, 2008, 11:22 PM   #3 (permalink)
JohnnyCrash's Avatar
"V 3&4"? What is that?
If you're meaning the inputs, two of them will be lower sensitivity, so that may explain the less noise there.
As far as the noise itself, it could be normal operating noise, but it would help if you could plug a guitar into it and describe the loudness and character of the noise a bit more.
Old May 15th, 2008, 02:12 AM   #4 (permalink)
Scott S's Avatar
My guess is that once you have a guitar plugged in, you'll be surprised at how much signal there is when the volume knob is on "2". I thought my 5E7 was hissy when I first powered it on, but it fills a room at "1" and is pretty loud by "2"!
- Scott
vB code is On
Forums Directory
