Old May 14th, 2008, 04:54 PM   #1 (permalink)
cable question
So, we're gearing up for our first gig (in a while, new band formed up blahblahblah) and I'm packing up the gear. I find a cable I don't recognize, and don't know what it's for. It's a 6 footer, says "C.B.I. Custom 20AWG made in USA". Is there a way to determine wether it's speaker cable or guitar cord? Without tearing it apart, I mean? it's nicely shrink-wrapped at both ends, so I can't really see the second solder joint.
Any tips?
marshman is offline   Reply With Quote
Old May 14th, 2008, 05:45 PM   #2 (permalink)
normally, speaker cables, even short ones should be at least 16 gage.
maybe google the wire name just in case
hockey_head is offline   Reply With Quote
Old May 14th, 2008, 05:52 PM   #3 (permalink)
I tried to look up C.B.I cables and Yahoo found it, but gave a warning about 'unsolicited emails' or some such.
I'm guessing that 20 gauge is probably instrument cable, then. Thanks.
Old May 14th, 2008, 07:23 PM   #4 (permalink)
emu!'s Avatar
I would suggest, try your amp/guitar setup with a 6 foot known guitar cable, then switch with the unknown cable. If you notice more hum and less output, the cable is probably NOT a guitar cable.
emu! is offline   Reply With Quote
Old May 14th, 2008, 09:18 PM   #5 (permalink)
Michaell's Avatar
blue tape
just an idea
I have all my cables marked with a blue tape.......it's blue dcut tape or blue masking tape.....guitars....speaker.....power cords......
x
Michaell is offline   Reply With Quote
Old May 14th, 2008, 10:57 PM   #6 (permalink)
woodman's Avatar
if you plug your guitar into your amp with it (for a microsecond) and if it buzzes like a banshee, it's a speaker cable. if there's any access into the plug, check and see if it's shielded (speaker cables aren't).
BAND PAGES:
Old May 14th, 2008, 11:03 PM   #7 (permalink)
Well, the 'squeal/hum' techniques were what I needed. I could remove the jack 'sleeves', but the heatshrink obscured the presence/absence of shielding.
Most of my cords/cables have the length and a letter sharpie'd on the ends--the length makes set-up easier, the letter so we know which mic/speaker is connected to what.
All of my guitar cords are known to me. Must be something someone left here after a jam of some sort. Thanks for the tips.
